  1. Kaboombee
    Kaboombee New Member
    Ohio
    I have already replaced the radiator, Radiator Overflow Coolant Reservoir Tank,
    Engine Coolant Inverter, and the coolant control value. I have bled and aired the system used 2 gallons of coolant my heat worked for about 1 week then stopped again and threw the same code P1121. I took it to the dealership the tech told me my husband could do this and this was what was wrong because they wanted 4500 to fix it ... any ideas what next
  2. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    4500 is a bit extreme. At least the tech was being honest in believing your husband could take on this project. Going forward, it might be time to use a different dealer for any future work or second opinions. Maybe that mechanic would take on jobs outside of work.
    Here is the workup for DTC P1121 : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/2054m/cip1121a.pdf
    Did you use OEM replacement parts from the dealership, or were the parts procured elsewhere?
    Many DIY enthusiasts will use a "mini-vci" cable ($20) and a copy of techstream (same software the dealer technicians use) on a windows device to diagnose/test/repair. How are you retrieving the OBD2 codes (DTCs) currently?
    JC91006 and Raytheeagle like this.
  3. rjparker
    rjparker Tu Humilde Sirviente
    7,952
    4,707
    Texas Hill Country
    kenoarto likes this.
  4. JC91006
    16,479
    8,397
    who did all the work on the car? Maybe you should check the coolant level again, make sure it's full at the radiator
    kenoarto and Raytheeagle like this.
  5. Kaboombee
    Ohio
    It's the only dealer around me that we went to my husband and myself did the work mostly him because he is a mechanic and the parts were local and online parts not but some were OEM and the scanner we used our basic as well as we borrowed a 3000 dollar snap on one and they all gave the same codes. It worked for about a week then stopped we are just at a loss and it seems no one around us works with hybrids. I have done the whole maintenance mode for the coolant I'm kinda at a loss and it's cold lol. Should the coolant always be at the top and can it take more than the 2 gallons
  6. Kaboombee
    Ohio
    And would low coolant throw the same code
  7. JC91006
    16,479
    8,397
    if your husband is a mechanic, have him replace the coolant valve again if he didn't use a brand new OEM Toyota part. Shouldn't take him long
  8. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Knowing that you currently aren't working with a $20 mini-vci cable and a copy of techstream to test and diagnose the issue, you can still go step-by-step through the above workup for DTC P1121 (linked again here : https://share.qclt.com/%E4%B8%B0%E7%94%B0%E6%99%AE%E7%91%9E%E6%96%AF%E5%8E%9F%E5%8E%82%E8%8B%B1%E6%96%87%E6%89%8B%E5%86%8Cpdf%E6%A0%BC%E5%BC%8F/Prius%20Service%20Manuals%202004/%E4%BF%AE%E7%90%86%E6%89%8B%E5%86%8C/04pruisr/05/2054m/cip1121a.pdf ), just skip the steps that require "the hand-held tester" (now replaced with techstream).
    Aftermarket control valves (and inverter coolant pumps) have been known to fail in short periods of time, confirm yours is working. If the valve was purchased at a local auto parts chain, it most likely has a lifetime warranty.
    If you had a mini-vci cable and techstream you could read the freeze frame data which would tell you the conditions that were met to throw DTC P1121. It could also tell you the temperature of the coolant, and actuate the control valve into all three positions.
    The manual calls for SLLC (super long life coolant), was an off brand of coolant or a stop leak product introduced into the system?
  9. rjparker
    7,952
    4,707
    Texas Hill Country
  10. SFO
    SFO Senior Member
    5,297
    4,235
    Northern California
    Don't know what to say, except those share.qclt.com links have been known to be safe on this forum for some years now.
    You could allow an 'unsecure connection' by giving the website "temporary permission", but only if the browser gives you such control.
    Another option would be to find the needed workup over here : Service Manuals - Google Drive
  11. ChapmanF
    15,560
    It's generally ok to view materials that are on an "outdated security configuration" site, as long as you are not planning to enter any personal or financial information there, and you're not concerned about whether eavesdroppers might be able to know what you viewed.
