  1. boriqua9719
    boriqua9719 New Member
    Within the past week, I have begun to experience the red warning triangle while driving in the 1st 10 minutes of starting vehicle (the warning is for temperature) and then goes away after about 15 seconds. At about the same time, I've lost all heat in the cabin. The radiator and thermostat have been replaced, but still the same symptoms. Has anyone experienced similiar? Could there be air in the system? Coolant level seems to drop overnight as I have been refilling each time.
  2. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    You shouldn't have to refill the fluid. Do you find any spills on the floor? It must be going somewhere. Air in the system will cause trouble, but I'm bothered about your need to refill on a regular basis. You need to get your Prius into the shop.
    Tom
  3. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    I wonder if they tested the thermostat before they installed it? It is not uncommon for a mechanic to take out the old thermostat, put it next to the new one, and accidentally put the old one back in. I learned a long time ago to drop the old thermostat in boiling water to test it and to do the same for the new one to make sure they open properly.
  4. Tideland Prius
    16,126
    *moved to troubleshooting forum*
  5. icarus
    icarus Senior Member
    4,884
    976
    earth
    If you are having to keep adding coolant, you got a leak! Perhaps it is small enough not be be noticed as it may dry as fast as it leaks. If you have no heat your coolant is to low.
    I wouldn't drive the car AT ALL until I got it figured out. Head gasket, cracked block, any number of things could "eat" coolant and show little sign. None of them good. If the red triangle is showing up it just confirms what you know. I suspect that the ICE is over heating due to lack of coolant.
    Icarus
