No homelink on a 2020 Prius Prime XLE?
Discussion in 'Prime Main Forum (2017-2022)' started by Shaunius, Aug 13, 2019.
Tags:
  1. Shaunius
    Shaunius Junior Member
    91
    24
    City of Angeles
    Why is Toyota doing this? Even my gen II prius has homelink :(, any way around this about to bite the bullet on the 2nd Prius as my gen ii is still alive :)
    49,492
    they are famous for decontenting
    Mendel Leisk and Shaunius like this.
  3. Shaunius
    91
    24
    City of Angeles
    strange though even my brothers brand new honda civic didn't have a homelink, are there any alternatives worth purchasing?
    49,492
    i'm not familiar, have a remote clipped to my visor :oops:
  5. CharlesH
    2,785
    1,152
    Roseville, CA
    My local police department recommends that one never leave garage remotes visible in the car when you are not in it. Smash-and-grabbers know that that is the key to your garage, after they check your address on your registration. I am talking about a situation of an attached garage, where the burglar wants to get into your garage and close the door, and then work on the interior door at their leisure. That is one of the advantages of homelink.
  6. bisco
    49,492
    fortunately (or unfortunately) i don't live in california :p
    #6 bisco, Aug 13, 2019
    will the engineer and Shaunius like this.
  7. smyles
    smyles Active Member
    332
    229
    US
    2020 Prius Prime
    XLE was previously Premium, which didn't have autodimming/homelink mirror either.
    Easy retrofit, btw.
  8. Shaunius
    91
    24
    City of Angeles
    how does one purchase this battery powered frameless mirror?
  9. Mendel Leisk
    38,727
    Yeah, looking through the 2010, 2016 and 2019 Canadian brochures: 2010 had "integrated garage door opener", on every level but base. For 2016 and 2019, it's only in "technology advanced package",
    Shaunius likes this.
  10. mr88cet
    mr88cet Senior Member
    2,311
    1,334
    Austin, TX
    I personally don’t know about what’s in the 2020 in particular. However, I’ll mention this: Although I’m glad our 2017 “Advanced,” highest trim level, does have it (looks to be the exact same part as in our 2009), we’re probably going to upgrade our garage-door opener to one with a rotating-code system, since that’s a lot more secure. Presumably, that will require us to use their particular door opener.
  11. Clark_Kent
    Clark_Kent Member
    44
    39
    Atlanta, GA
    2020 Prius Prime
  12. Salamander_King
    Salamander_King Senior Member
    10,975
    8,868
    New England
    Is HomeLink useful for anything other than opening a garage door? Our recently purchased Pathfinder Hybrid (used) came with HomeLink, but since we do not have functioning garage, I never bothered to set it up. It is the first car ever to have this option for me.
  13. drash
    drash Senior Member
    2,483
    1,256
    Upstate NY
    Supposedly it’s suppose to work with X10 based remote RF receivers. That way you can control lights and appliances that are plugged into the X10 controllers. Haven’t really kept up on it since Radio Shack went out of business.
    Unsupervised!
    Salamander_King likes this.
  14. smyles
    332
    229
    US
    2020 Prius Prime
    Keep in mind Prime's mirror has longer 'stem', otherwise it won't fit properly, or you'll have to remove/cut the sensors cover. .
  15. Mendel Leisk
    38,727
  16. jb in NE
    jb in NE Senior Member
    2,233
    1,596
    Nebraska
    2018 Prius Prime
    Homelink works with rotating codes.
    mr88cet likes this.
  17. Kicks07
    Kicks07 Junior Member
    33
    29
    Rochester, NY
    2020 Prius Prime
    All models come with Amazon Alexa I believe. If you had a smart garage door or bought one of the easy to convert ones, you could use Toyota+Alexa to open it. It's a huge go around, and not convenient at all, I only offer it as an option. I have homelink and I'm thinking about doing it anyways.
  18. Shaunius
    91
    24
    City of Angeles
    Picking up the part now, will report back had to pick up floormats also
  19. Shaunius
    91
    24
    City of Angeles
    Fml I just realized it’s not autodimming major let down
  20. PT Guy
    PT Guy Senior Member
    1,085
    710
    Washington, the state
    "we’re probably going to upgrade our garage-door opener to one with a rotating-code system, since that’s a lot more secure. Presumably, that will require us to use their particular door opener."
    To use the Homelink on a rotating code device (a) follow the instructions in the car's owner's manual, (b) go on the web site from the opener maker for different instructions. One or the other will work.
