No Horn!! No power to buttons on the Steering Wheel!!!??
Discussion in 'Gen 2 Prius Main Forum' started by svldvc, Jan 12, 2011.
  1. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
    Hi guys.
    I have a 2006 Prius.
    For some reaon I've noticed that the buttons on the steering wheel Do NOT glow and they do NOT work...:confused:
    Horn doesnt work either!
    And the light on the driver side door (for windows/lock/unlock) are NOT lit up either...?? It's all black and dark @ night.. :(
    Is there a fuse/relay for these type of things?
    If so...where do I start looking?
    I took off the Airbag from Steering wheel and removed steering wheel to double check everything...and everything looks good. No damage. Wires are all connected well etc.
    Anyone please? :confused:
  2. svldvc
    svldvc Member
    102
    Charlotte NC
    2014 Prius v wagon
  3. drew_flux
    drew_flux Junior Member
    73
    22
    sydney australia
    broken wire in the spiral cable? maybe its not pluged in behind the steering covers
  4. pEEf
    pEEf Engineer - EV nut
    720
    576
    Berkeley, CA
    Yeah, sounds like a fault in the spiral cable (clock spring). Is the SRS light on (Airbag)? If it is, then I'd definitely bet on it!
  5. homiejoe2
    homiejoe2 Junior Member
    new york
    So i finally made an account but can't post yet. Really need some help as this is time sensitive. Hopefully someone will see this and respond-
    Okay I've read a few threads about upgrading the stock prius horn. I think the wiring to my horn is incorrect.
    The stock prius horn comes with this connector (cant post the link b/c im new but the black and yellow standard connector)
    The single black wire that connects to the back of the connector was disconnected and parts of the plastic clip were chipped. I wasn't getting any sound when hitting the steering wheel.
    I didn't want to buy a new connector for $70 so i bought these aftermarket horns:
    Instead of using both horns and the relay plug- i simply took the low tone horn and twisted the prius' black copper wire to one of the male spade connectors supplied in the pack above^ and used a twist on wire connector/cap. I grounded out the horn to the hood latch.
    Now- The horn works well- but only between 3-6 "beeps"- then it goes dead. But if I detach and then reattach the spade connectors to the horn it will again work between 3-6 "beeps".
    Any ideas? Is there a short in the prius' black wire? Doesn't sound like a blown fuse to me...
