No interior lighting after turning on headlights
Discussion in 'Gen 3 Prius Technical Discussion' started by PutPutMobile, Feb 25, 2018.
  1. PutPutMobile
    PutPutMobile Senior Member
    292
    518
    Buena Park, CA
    Anybody have encountered this problem? After putting on my fog lights and drls, it just happened tonight that my interior lighting shuts off when my headlights are turned off.. I can't see how fast i am going on the road...plus the bottom interior where the climate control doesn't illuminate.. I can't figure out if it's the fuse or if it's a wiring problem.
  2. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Most likely the dimmer thumb rolling rotary adjuster instrument panel thing is causing that. When completely dark, and dimmer is all the way down, dash lights goes off like that.
    Raytheeagle likes this.
  3. PutPutMobile
    292
    518
    Buena Park, CA
    crap.. duhh.. i'm gonna check right now.. LOL..
  4. PutPutMobile
    292
    518
    Buena Park, CA
    fixed.. hahaha.. my bad.. newbie error.. they accidently turned the dimmer off..
  5. PutPutMobile
    292
    518
    Buena Park, CA
    i was scared like crap driving in the streets earlier..
  6. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    Glad that worked out for you. Post a photo of the fog lights you installed if you get the chance.
  7. PutPutMobile
    292
    518
    Buena Park, CA
    I have a problem with that right now @grid .. it's pointing high like high beams.. I need to have it adjusted
