No jack points for flat tire change?
Discussion in 'Gen 5 Prius Care, Maintenance and Troubleshooting' started by Nntw, Sep 23, 2023.
  1. Nntw
    Nntw Active Member
    396
    244
    Toronto
    2023 Prius Prime
    I was all set to go buy a traditional scissors jack as part of my emergency kit... thought I'd check if the car used the traditional 'rail' approach...
    and then I see there are no lifting points on the sides, but mounts for floor jacks, front and rear!
    How are other folks addressing this?
    From my owners' manual:
    #1 Nntw, Sep 23, 2023
  2. KMO
    KMO Senior Member
    1,518
    395
    Finland
    2023 Prius Prime
    There are side jack points for changing tyres where you'd expect. (According to the manual, not got under to have a look yet).
    tovli likes this.
  3. Nntw
    Nntw Active Member
    396
    244
    Toronto
    2023 Prius Prime
    huh. will take another look. thanks
  4. Mendel Leisk
    38,653
    That actually looks like a reinforced zone, which is refreshing. Our 3rd gen designated places to use the scissor jack, ID’s the zones with small cut-outs at the ends of the zones, but as far as I can see provide no reinforcement of the proscribed zones, say an extra layer of plate, or a rolled-over edge.
  5. lohikaarme
    lohikaarme Active Member
    329
    324
    NY
    2023 Prius
    Limited AWD-e
    They are definitely under there… having jacked the car up 2x already on quickjacks when i installed the catshield and did the first oil change. Just look under the car, you will see the reinforced sections of the rails.
  6. fuzzy1
    10,164
    Page 528 in the U.S. Owner's Manual.
  7. Mendel Leisk
    38,653
    The front/centre jacking point (per pic in post #1) is way back, per gen 4/2; that's one good thing about 3rd gen: that point is only about 15" in. The car does bow a bit as you lift there; I'll take it.
  8. Nntw
    Nntw Active Member
    396
    244
    Toronto
    2023 Prius Prime
    Thanks to all for the correction.
    there ARE jackpoints- just further from the edge of the car, and without the little 'cutouts' in the rail to draw attention to them.
  9. Mendel Leisk
    38,653
    For a comical counterpart, this is what you get on gen 3, a knife-edge, no extra plate. I never put safety stands there, worked out more sensible points.
  10. otatrant
    otatrant Member
    145
    102
    San Francisco
    2023 Prius Prime
    XSE Premium
    From the manual.
    "The jack point guides are located under the rocker panel. They indicate the jack point positions."
    Took me a couple of looks and feels to find them but here is a short 2 second movie of what the jack point guides look like on the bottom edge of the rocker panel (little triangle).
    tovli and KMO like this.
