No lights turn on when starting car
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by nhxvisual, May 30, 2018.
  1. nhxvisual
    nhxvisual New Member
    los angeles, ca
    i bought a used 2006 prius
    it failed smog, so so i contacted seller, he told me he'd fix it,
    never owning a Prius, I was surprised because I never saw a check engine light, even with a flashlight i couldnt see it on the dash so i figured prius's dont have those lights.
    when i turn on the car it goes into ready thats basically all that pop ups, if i turn the headlights on the symbol lights up
    anyway
    the seller told me to go to his mechanic, his mechanic put a new catalytic converter my smog guy said the code (p0420 i think) was cleared
    but when i turn the car on the CEL doesnt turn on for the warning light check.
    I called another mechanic, he said the seller probably took out the cel light because he wanted to sell a car that didnt have the light on...
    now the seller is saying its been like 4 weeks and hes not responsible he already put the CC into the car. and its my problem now
    the issue is I cant put it in my name til it passes smog.
    now I just want to sell it and I cant even do that.
    can anyone help me? lololol
    im super broke, and this was a bad idea to get but thats done and over so now I need to fix this asap
  2. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    Your post is hard to understand. Are you saying the only thing you see on the dash is the ready light?
    Be aware there is a very common issue the Prius has with the entire dash LED assembly fails and goes dark.
    The dash assembly is called the combo meter.
    Use the Search forums button up top and search the word:
    combination meter.
    Read on.
    Raytheeagle likes this.
    49,708
    contact the state attorney generals office of consumer affairs, and find out what your rights are with a used car purchase. they may be available on line.
  4. JC91006
    16,494
    8,404
    If there are no lights on, why can't you pass a smog check?
  5. nhxvisual
    los angeles, ca
    ok, so let me clarify
    the "ready" light turns on, but no warning lights do, like the check engine light, the triangle, i can't even see any light symbols after VSC I think, it goes totally blank, Even shinning a flash light, there seems to be nothing there at all,
    so when it comes to the check engine light,
    for you to pass, when you turn the car on, the check engine light needs to light up to prove it works, if it doesnt show on the start up check, its a fail.
    at least that is what 3 mechanics told me.
  6. nhxvisual
    los angeles, ca
  7. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,482
    Bay Area, California
    2019 Prius Prime
    See @edthefox5 ’s post #2;).
    The combination meter is the issue.
    Good luck and keep us posted (y).
    edthefox5 likes this.
