No More 999.9MPG! (For a while)
Discussion in 'Prime Main Forum (2017-2022)' started by mr88cet, May 26, 2017.
  1. mr88cet
    mr88cet Senior Member
    2,311
    1,335
    Austin, TX
    Had a half day off from work. Had to get away. Had to burn off at least some of the full gas tank that came with our P.Prime. Had to finally start breaking in the ICE!
    Took a ~105mile round trip to Pedernales Falls State Park (Central Texas). That "last drive" presumably refers to the 52.5ish miles back, which was pretty much entirely HV mode. I think I had about 4 miles of EV room, and I still had 1.2 miles when I got back home, so pretty much entirely HV. 67.6MPG, apparently!
    The ECO Dashboard says that my cumulative MPG is down from "999.9MPG" to 279.1MPG. The car itself says ~184MPG. Not sure whether either is correct, since they disagree...
    It seemed a little less responsive to the accelerator in HV mode than what I'm used to in EV mode. Can't beat that instant torque! In HV, it seemed to be working hard, whereas EV mode feels like gliding on teflon!
    iPad ? Pro
  2. Derek Lee
    Derek Lee New Member
    Nashville tn
    I'm new here stupid question how do I create a new post?
  3. mr88cet
    2,311
    1,335
    Austin, TX
    Are you on the website itself or the "Tapatalk" app?
    iPad ? Pro
  4. Derek Lee
    Nashville tn
  5. mr88cet
    2,311
    1,335
    Austin, TX
    If you're on the Tapatalk app on your iPhone, then look for the pencil&paper icon in the top right:
    I don't immediately recall what to look for if you're looking at the PriusChat website on Safari...
    iPhone ? Pro
  6. Prodigyplace
    12,403
    11,681
    Central Virginia
    I assume you mean post a new thread.
    Select the forum and there is a large button saying post new thread.
  7. priuscatprimeguy
    priuscatprimeguy Senior Member
    2,730
    2,640
    Farmington Hills, Michigan
    I think the ECO Dashboard resets to zero MPG on the 1st of every month.
    mr88cet and Prius from Dad like this.
  8. mr88cet
    2,311
    1,335
    Austin, TX
    OK. Interesting...
    I haven't yet had the car on the first of any month, but that's good info.
    I'm guessing your saying, in part, that that's one way the car's numbers might mismatch the ECO Dashboard's numbers?
    iPhone ? Pro
    priuscatprimeguy likes this.
  9. priuscatprimeguy
    2,730
    2,640
    correct, especially if the car's numbers roll over to the next month or so.
  10. mr88cet
    2,311
    1,335
    Austin, TX
    I'd be surprised if the car's numbers wouldn't be continuously maintained, unless/until you explicitly reset them, but I don't claim to know for sure...
    So I imagine that's another way they could mismatch -- explicitly resetting the car's numbers.
  11. priuscatprimeguy
    2,730
    2,640
    are you referring to the trip ODO and hand calculations of your gas fill up?
  12. mr88cet
    2,311
    1,335
    Austin, TX
    Resetting a trip ODO.
    iPhone ? Pro
  13. priuscatprimeguy
    2,730
    2,640
    well don't reset it. wait till you fill up your tank. I've gone 1666.7 miles before I reset it and consumed 9.6 gallons of gas:cool:
    tanner9868 and Son of Gloin like this.
  14. mr88cet
    2,311
    1,335
    Austin, TX
    Yip, I've done none of the above so far, so it's a little puzzling that they don't match better.
    iPhone ? Pro
  15. priuscatprimeguy
    2,730
    2,640
    ok, now I'm confused :confused: what specifically do you mean by "car's numbers?"
  16. mr88cet
    2,311
    1,335
    Austin, TX
    I can't remember exactly how I have all of the displays set, but it displays a cumulative MPG number under the Speedo, saturated at 199.9.
    iPhone ? Pro
  17. priuscatprimeguy
    2,730
    2,640
    yup, useless mainly because it maxes out at 199.9:mad:
  18. mr88cet
    2,311
    1,335
    Austin, TX
    Yep... but it did drop back down below 199.9MPG after today's road trip, to … about 184MPG, as I recall.
    Earlier I'd noticed that it seemed to drop down almost immediately when we took a trip across town to a mall that doesn't have a charger. I think I was not imagining that, and in fact it did drop down pretty quickly. However, it took a lot longer today to drop below 199.9MPG, almost certainly because I have a lot more pure-EV-mode miles on the car this time. And of course I'll keep racking up EV-mode miles again tomorrow, and the next day, and the next...
    iPhone ? Pro
    ArcPrime likes this.
  19. priuscatprimeguy
    2,730
    2,640
    yup, but you see, the thing is the cumulative miles you don't see (beyond the 199.9 MPG) probably won't match the ECO dashboard. Mainly because the average MPG over several months (or even a month and a half) is substantially larger than the one month ECO Dashboard reading.(I'm figuring you already knew this, right?)
  20. ArcPrime
    ArcPrime Active Member
    201
    166
    Arcadia, California
    I believe there is an ODO avg MPG 199.9 bug. Remind me of PC Y2K bug.
