No more gen2 cars on long hot trips
Discussion in 'Gen 2 Prius Main Forum' started by JC91006, Jul 9, 2018.
  1. JC91006
    16,470
    8,383
    So I drove from Los Angeles to Las Vegas this weekend in 110 degree heat and for the first time didn't see any gen2 prius cars on the 15 freeway going or coming back from Vegas. I did see a brave soul in a gen1 though.
    I think many people are worried breaking down in 110 degree heat, not taking their gen2 prius on long road trips anymore. Just me in my 2005 braving the heat without any fear
    SFO, padroo, m.wynn and 3 others like this.
  2. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,476
    Bay Area, California
    2019 Prius Prime
    Maybe they wanted to save their luck for the destination ;).
    You go there to watch Evel Live:whistle:?
  3. Starship16
    Starship16 Senior Member
    1,348
    1,452
    Beach Christmas
    deleted
    #3 Starship16, Jul 9, 2018
  4. JC91006
    16,470
    8,383
    Travis Pastrana! I stayed to watch his first jump at Planet Hollywood but couldn't get myself to walk across to Caesars Palace to see the final jump. Here's a picture without the crowd at Planet Hollywood, I thought there would be more people..... IMG_19121.jpeg
    m.wynn and Raytheeagle like this.
  5. Raytheeagle
    11,251
    15,476
    2019 Prius Prime
    That does look sparse:(.
    They had a lot of theatrics for the event. Not as much as the golden knights home games, but still done up(y).
  6. JC91006
    16,470
    8,383
    There has been many reports of inverter pump and hv battery failures on the gen2 cars, both items will pretty much keep you from driving it long distances. Also it's very hard to detect when they are about to fail, so there's really no true warning signs (except a weak battery).
    I would only drive long distances with a gen 2 if it has had the inverter pump replaced within the last 80k miles and if the HV battery is not refurbished and under 8 years old.
    A new Prius will easily go 8 to 10 years without major issues, but after that, it's a roll of the dice.
  7. wjtracy
    wjtracy Senior Member
    11,312
    3,588
    Northern VA (NoVA)
    I think you just saying Gen2 Prius owner are not gamblers.
  8. JC91006
    16,470
    8,383
    I think the owners that know about their cars will take the risk. But most owners wouldn't want to risk a battery failure (I think this is well known, not so much the inverter pump failures) on a long distance trip.j
    I think we should have a recommendation for people to replace their inverter pumps, same rule like a 12v battery. After 5 years....best to replace it.
    Raytheeagle and bisco like this.
  9. wjtracy
    11,312
    3,588
    Northern VA (NoVA)
    my inverter pump just went bad a few weeks back
  10. JC91006
    16,470
    8,383
    from the time the recall was done, how many years/miles did you log on that pump?
    DLC82SV likes this.
  11. breakfast
    breakfast Active Member
    266
    199
    Maybe it's because Simon Cowell is going around crushing every Gen 2 Prius he sees in LA... ;)
    (Warning, contains graphic scenes of Gen 2 Prius destruction :()
    Raytheeagle and JC91006 like this.
  12. wjtracy
    11,312
    3,588
    Northern VA (NoVA)
    Looks like I did the recall Jan-2011 at 81,000 miles...now at 175,000 miles
    m.wynn and JC91006 like this.
  13. JC91006
    16,470
    8,383
    Pretty close to 100,000 miles. So to change it out before 80,000 miles would be safe, unless you're a bit of a gambler
  14. bisco
    48,945
    is it time or miles? i suppose operating time?
  15. JC91006
    16,470
    8,383
    That's a good question. I think many people all jumped on the recall at the same time, that's probably why we are seeing a rash of failures all at once. Maybe in the time frame, people averaging 15k miles a year would be close to 100k miles?
    m.wynn, Raytheeagle and bisco like this.
  16. wjtracy
    11,312
    3,588
    Northern VA (NoVA)
    Re: inverter pump- it's a cool powerful little pump operating at 12v- I was noticing YouTube has some videos people re-purposing the pump for general water pumping duties.
    m.wynn, JC91006 and bisco like this.
  17. bisco
    48,945
    i'll have to look up my daughters '08 recall date. don't need that problem on her 400 mile weekend r/t drive. is heat a factor?
    Raytheeagle likes this.
  18. JC91006
    16,470
    8,383
    If she's planning to keep the car, just have her change it. It'll be good for another 5-6 years
  19. wjtracy
    11,312
    3,588
    Northern VA (NoVA)
    Dealers here seem to be charging $750 for replacement which is yikes!
    On YouTube Lucious Garage said they charge like $275, but that was a few years back.
    You can get the pump on Amazon for about $60 and it's not a bad DIY, though I got half way through it and decided to let my mechanic do it as he was a Toyota guy.
  20. JC91006
    16,470
    8,383
    Where did you get stuck? I think this repair is one of the more straight forward ones, not too cramped for space. Just remove the headlight and clamp the hoses. Then unbolt it.
    $750 from Toyota is crazy, the book time and parts price will equal around $450 from Toyota's current labor rates
    nssdiver likes this.
