No P Shift seen
Discussion in 'Gen 3 Prius Technical Discussion' started by Stuzia, Jul 22, 2019.
  1. Stuzia
    Stuzia New Member
    Germany
    Video here:
    we.tl/t-i9k0nVskqj
    I have a Problem with my Prius 3, 2010. Sometimes difficult start- Navigation vanish and Motor cannot be started so I have to use emergency start. Sometimes no Problem.
    I let it twice chek up in car Service but nothing was found. I was advised to buy a new battery but it is still good (also checked).
    Can anyone help me.
    52,380
    welcome!
    can you give us the rundown on your 12v battery testing?
  3. Pluggo
    Pluggo Senior Member
    608
    534
    Folsom, Pennsylvania
    Your 12 volt battery is 9 years old? It should be replaced. It is time.
  4. ThatDudeOrion
    ThatDudeOrion Member
    95
    87
    Central, NJ
    You need a new 12v auxiliary battery. When you have a car that won’t start on its own but starts with a boost/jump it can only be 1 of 2 things. Either the alternator isn’t charging the battery or the battery can’t hold the charge the alternator is giving it. In the Prius platform, its always the battery that has failed. There is no alternator.
  5. bisco
    52,380
    couldn't it be something less expensive :cool:
  6. ASRDogman
    ASRDogman Senior Member
    7,808
    3,980
    $150-200 for a battery in NOT that expensive. And for the Prius, it's 5+ years.
    For my van, I paid $100+ for a 4 year battery.
