No phone option available??
Discussion in 'Gen 3 Prius Audio and Electronics' started by Evoking, Aug 12, 2020.
  1. Evoking
    Evoking Junior Member
    91
    16
    Pomona
    Hi so I have a 2010 since I purchased my Prius I haven’t had the option to connect my iPhone via the Navi I can hook it up to Bluetooth but I do not get the option to link it via phone pair I’ve already seen videos on you tube how to connect my phone but the thing is I don’t see the option to click on my phone here is a picture of my navi
  2. Tideland Prius
    16,155
    Press the INFO•PHONE button on the right.
  3. Evoking
    91
    16
    Pomona
    Tried that and the only thing that comes up is map data and calendar but there should be a phone there and I checked eBay and same some of the radios are missing the phone option
  4. Tideland Prius
    16,155
    Yeah. You’re missing an icon in that menu. Was this a factory option or did someone install it on a base Prius. Hmm.
  5. Evoking
    91
    16
    Pomona
    No this is a premium Prius solar panel on the roof moon roof leather interior seat warms the full 9 even on the steering wheel it has the option to answer calls or hang up so yeah I don’t know
  6. Tideland Prius
    16,155
    Have you tried a reset of the MFD?
  7. Evoking
    91
    16
    Pomona
    No what’s that?
  8. Evoking
    91
    16
    Pomona
    Of I found out what is mfd but how do I reset it on a 2010 prius
  9. Tideland Prius
    16,155
    Crap. I thought there was a reset. There's only "delete personal data" within SETUP --> General.
    Hmm....a hard reset would be disconnecting the 12V battery, waiting a few minutes (say 5 minutes) then reconnecting it. You'll have to initialise the auto up/down power windows and the moonroof as well as radio presets but it could reset the headunit.
    It's really odd that the phone section doesn't exist.
  10. Evoking
    91
    16
    Pomona
    Yeah your telling me but yes I also disconnected the battery and left it like that for half and hour and still nothing
  11. Tideland Prius
    16,155
    I wonder if the bluetooth module is disconnected. I don't know how it's installed but if it's a module (rather than built in), then maybe the previous owner disconnected it and thus the audio system doesn't recognise it and blanks it out?
  12. Evoking
    91
    16
    Pomona
    It’s funny you say that because I was thinking the same thing because my car has built in sos and only when I start up my car it says that there is and error with sos and to contact the dealer so I’m thinking something happened back there or something was unplugged
  13. Attila Fekete
    Attila Fekete Member
    164
    59
    Budapest, Hungary
    I don’t think there is external module for bluetooth, but loose cannector may cause the problem. I would double check the antenna connectors.
    Is there bluetooth settings on your HU, where you can see the paired phones - or that’s what you missing?
    There maybe an option to disable bluetooth completly.
  14. Evoking
    91
    16
    Pomona
    So Bluetooth works no problem but I can’t make or call anybody on my Navi
  15. Grit
    Grit Senior Member
    6,148
    4,057
    Wilkes Land
    Navigation is for going to places with addresses entered, not for phone calls.
  16. Attila Fekete
    164
    59
    Budapest, Hungary
    On my HU there is an option to enable voice call, audio and internet access - these three things can be enabled / disabled separatly.
    If you have such option it may worth to check it.
  17. Evoking
    91
    16
    Pomona
    Where can I see this
  18. Tideland Prius
    16,155
    How do you check to see if bluetooth works? Are you able to play music from your phone on the head unit?
    Also, what if you press the unhook button on the steering wheel? Does it bring up the phone menu?
  19. Evoking
    91
    16
    Pomona
    So Bluetooth does work and yes I can play music but when I press the hang up or call button nothings happens you just hear a beep
  20. Tideland Prius
    16,155
    Ok this is so weird then. What the heck is going on.
