No power after battery replacement
Discussion in 'Gen 2 Prius Technical Discussion' started by Brodaag, Jan 29, 2017.
  1. Brodaag
    Brodaag New Member
    Austin TX
    I got an error code that a cell in the high voltage battery was bad so removed it, located the defective cell and replaced it. Afterwards every cell read around 7.9 - 8 volts, and the battery itself 220 volts. I reinstalled the HV battery, replaced the 12v battery, and when I connected the orange service plug nothing happened. No power to the dash or to anything. I read the voltage on the battery while installed and it was bouncing around from 0 volts to 300 and everywhere in between. I disconnected the battery from the car and the voltage now reads 217. I checked the voltage on the cells as well and they all dropped a couple tenths. I have double checked every connection and all the fuses.
    Does anybody know what's wrong?
  2. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    Recheck your 12v connections including the 12v battery cable to body ground bolt. You may also want to check the fuse attached to the 12v positive terminal.
    Your complete loss of power issue is definitely with the 12v system and not the traction battery.
    thatoneraccoon likes this.
    51,154
    welcome!
    most likely, you haven't seated the orange high voltage safety connector properly. happens to most people the first time.
    see you tube for instructions about sliding it up, after locking it down.
  4. Brodaag
    Brodaag New Member
    Austin TX
    Thanks for the help. All the connections are good and the orange service plug is properly seated. I don't suppose there is anything else that could be causing this is there?
  5. bisco
    51,154
    i won't argue it then, except 9 out of 10 people who think it's properly seated are incorrect. if it's not that, there has to be something else. are the 12v connections clean and secure, especially neg to ground at body?
    strawbrad and jeff652 like this.
  6. greasemonkey007
    greasemonkey007 Active Member
    287
    106
    South Central Arkansas
    Just to make sure, did you:
    1.) insert the service plug
    2.) fold the lever upward 90 degrees
    3.) push straight down on the plug to close the safety switch?
    strawbrad likes this.
  7. jeff652
    jeff652 Senior Member
    607
    624
    Idaho
    This is our number one reason for post sales customer calls. I ask them if they can remove it by hinging it up without sliding it sideways. 9 out of 10 times they say "Yup, hinges right out". I then explain that the fact that it hinges without sliding means it's not installed correctly. Only at that point do the callers finally understand.
    I need to make a demo video for this one . . .
    EDIT: Second most common for a no-start is not pressing the Start button twice.
    strawbrad and valde3 like this.
  8. Brodaag
    Brodaag New Member
    Austin TX
    Yes
  9. Brodaag
    Brodaag New Member
    Austin TX
    Yes, double checked them all
  10. bisco
    51,154
    must be a blown fuse i guess. is the dome light in that circuit?
  11. Brodaag
    Brodaag New Member
    Austin TX
    I was able to get a voltage reading off of it after installing the plug so I'm pretty positive it's seated correctly. Pressed the button twice as well. There just ain't any power. Damnedest thing.
  12. bisco
    51,154
    are you getting 12+ volts at the jump point under the hood?
  13. Brodaag
    Brodaag New Member
    Austin TX
    Welp, I started over and went over everything once more to make sure, and although I didn't notice anything loose or unseated, it turned on. Obviously I missed something, who knows what. But thanks everyone for your help. I'm glad it was the simple solution.
    jeff652 and bisco like this.
  14. bisco
    51,154
    all the best.(y)
  15. Brodaag
    Brodaag New Member
    Austin TX
    So I have a new issue after changing a cell out of the HVB and getting it running again, now the car is very sluggish and hardly accelerates, it also won't accelerate past 40 mph and doesn't really want to decelerate after you take your foot off the pedal. All the warning lights are on, and the error codes I get are:
    P0AFA
    P3011
    P3022
    P0A80
    Is it possible the issue is the HV ECU?
    I'm strapped for cash so I don't want to buy one and have it not be the problem.
  16. MTL_hihy
    MTL_hihy Active Member
    536
    261
    Maritimes, Canada
  17. Brodaag
    Brodaag New Member
    Austin TX
    Thanks, I didn't actually know they made OBDII to USB adapters. I'm going to try that. What software do you use?
  18. bisco
    51,154
    mini vci comes with toyota tech stream software.
  19. MTL_hihy
    536
    261
    Maritimes, Canada
    X2 (Techstream, same program as the Toyota dealers use)
    You can see how to install it and what you need here.
    XP Home or XP Professional with Mini VCI? | Page 3 | PriusChat
    The mini VCI cable should have a CD with drivers, make sure to follow the proper install order for it all to work.
  20. Brodaag
    Brodaag New Member
    Austin TX
    Nice, thanks guys!
