No Power - No Response - Battery Good - Jump Didn't Work
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Austin Middleton, Jan 4, 2014.
  1. Austin Middleton
    Austin Middleton New Member
    I have a 2007 Prius w/ 93k miles. Went on vacation for a week and came home. Won't turn on at all, no lights, nothing. Like a dead battery, but it has a brand new 12v, and a jump didn't help at all.
    Any thoughts? Perhaps a fuse?
  2. YOLOsoBuyaPrius
    YOLOsoBuyaPrius Junior Member
    77
    Nebraska
    Orange Service plug? this could result in no power anywhere Did you turn off the smart key? How long were you gone? The 12v could be dead causing the computers to have no communication or power but you said it was new When did you replace it?
  3. Austin Middleton
    Checked the voltage on the battery. Also checked the 120Amp fuse. Also good. Not sure what else to check. :(
  4. YOLOsoBuyaPrius
    77
    Nebraska
    Have you tried inserting the smart key in the slot? Did you have to use the mechanical key to get in when you got home?
  5. Rich12
    Rich12 Member
    176
    29
    Have you tried starting the car? Spark plugs?
  6. bisco
    51,155
    does the dome light fuse come into play here?
  7. Austin Middleton
    Inserted the key. Checked to make sure the key has power. Again, no power, so no lights, no starting. Nothing.
  8. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    Using a voltmeter what is the DC voltage on the front jump point in the black plastic fuse box next to the Inverter under the red plastic tab you flip up. Whats that measure to ground?
