No Power to the Entire Car: Ignition, lights, etc.
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by BobHawaii, Jan 20, 2018.
  1. BobHawaii
    BobHawaii New Member
    Oahu
    Our car is powered again, but why, we don’t know.
    Initially, the car would not start at all, neither the headlights and map light would work. Nothing had power.
    Would like to know if you have an idea to what the problem might have been?
    Gas was full.
    Moved the fuse box, which kind of sparked the green light on to the power button, but very briefly. We then just waited, and suddenly power was back on to the entire Car.
    After we parked, we left the car for roughly 2.5hrs, everything was fine before, drive great from point a to point b.
  2. padroo
    padroo Senior Member
    2,763
    2,250
    Sounds like a loose connection. I would start with the 12 Volt battery and the ground where it attaches to the vehicle.
    If moving something made things light up do it again looking for loose connections.
    ztanos and Prodigyplace like this.
  3. Dxta
    Dxta Senior Member
    1,932
    767
    Lagos
    The problem might be coming from the fusebox lo action at the hood.
    Check power supply from the battery (12V), to the fusebox itself. If you don't have power coming to the fusebox, there's an open or shortcuit on the circuitry.
    If there's power to the fusebox, then I bet one of the ignition ON relays/fuse might be failing.
    But in this case, yours might be a short circuit problem, in the wiring or fuses/relay, considering that its only when the car is cold, you experience this problem. But when it has being driven like you've done for some time, it appears to have fixed itself.
    Y it appears to have fixed itself after you drove is because the wire harnesses in the related circuits, undergo thermal expansions during those times you drove the car, providing the necessary contacts on the relays or... Immediately it cooled down, the wires contracts, and the circuit is broken.
    PS: Check connectors also.
    Dxta
    ztanos likes this.
  4. fuzzy1
    10,172
    And wiggle the fuses themselves too, not just the wires to the fusebox.
    Just an open circuit, not a short circuit.
    Short circuits cause excessive currents, leading to sparks or blown fuses or hot parts or drained batteries. Lack of current (without a drained battery) means an open circuit.
    padroo likes this.
