No power while driving
Discussion in 'Gen 3 Prius Main Forum' started by shankyyy, Jul 10, 2010.
  1. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    I was driving through the Appalachian range in WV last weekend. During an upslope, I could hear the car dragging, the noise that we hear when we go on a steep slope. But even after I reached a plateau, I had a hard time going above 65. The more gas I pressed, the car never went above 65. The noise was still evident. After a few times, I switched to Normal mode (from ECO), and it marginally seemed to improve but not completely ok. For about 120 miles of Appalachia, I had this thing happen. Is this normal? I thought newer cars, especially on a plateau should not have this much loss of power. Any insights would be appreciated.
    I am going to get my 5000 mile service today, and anything obvious I could bring it to the dealer.
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    What was the traction battery icon indicating during this time? Have the dealer check for codes while it is there.
  3. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    i do not remember the traction battery but i am sure it was not very low.
    during the oil change, the dealer checked the codes, and found nothing wrong. he said there is nothing wrong. not sure what to make of it.
  4. bwilson4web
    16,010
    Could you provide some sort of Google map showing the route or sections where this occurred?
  5. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    [​IMG]It is the I-68 stretch from Morgantown all the way until Maryland, about 120 miles. i was driving from columbus to DC.
    [ame="http://maps.google.com/maps?f=d&source=s_d&saddr=columbus,oh&daddr=Washington,+DC&hl=en&geocode=FVjCYQId9okN-ylx3pC5wYk4iDEztbHP-GYy5A%3BFQh-UQIdsoRo-ylb5PZa3sa3iTEqXYjUIkVSwg&mra=ls&sll=37.0625,-95.677068&sspn=30.682067,81.474609&ie=UTF8&ll=39.909736,-79.255371&spn=3.606633,10.26123&z=7"]Columbus, OH to Washington, DC - Google Maps[/ame]
  6. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Is it possible you still had the "shifter" in B mode?
  7. Kennewick Man
    Kennewick Man Junior Member
    42
    Kennewick,Wa.
    X2:eek:
  8. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    "B" would not limit the power. In fact, the car would feel more powerful (though it wouldn't be) due to the more "direct" response to the pedal.
    Did you accidentally cover the battery cooling intake? What you experienced is what happens when the car looses the use of the traction battery, either from discharging on a long uphill or from temperature (the system won't use it when it is too hot).
  9. shankyyy
    shankyyy Member
    172
    Charlotte, NC
    - I was not in B mode, for sure. I was driving in D all the way
    - Battery Cooling Intake - Is this the one to the right of the right rear seat? If so, it is possible as there were two people at the back.
  10. Husker4theSpurs
    Husker4theSpurs Active Member
    656
    128
    Papillion, Nebraska
    My guess would be you were using a lot of assisting battery power getting up the inclines, so at the time of a lot of engine noise and not much power you were basically using MOSTLY or ONLY the engine power ... no accompaniment by the battery. It happens ... nothing to be concerned about.
  11. timo27
    timo27 Member
    316
    52
    Baltimore, MD
    Any chance the rear vent was obstructed?
