No Prius Radar Detection
Discussion in 'Gen 2 Prius Main Forum' started by jgod12, Feb 6, 2009.
  1. jgod12
    jgod12 Junior Member
    33
    Hanover, PA
    Is it possible that at a certain angle the Prius is not detected on radar? This has happened to me two times where I would drive into my neighborhood and a stand alone mounted speed detection device(installed by the local police department only 2 times that I know of) would not register my speed. I was so confused by this:confused:, minutes later I took my other non-hybrid van on the same road and the dectection worked perfect telling me my speed. If so, could it be the slope of the windshield or is my Prius radar really stealth?
  2. LanMan66
    LanMan66 Junior Member
    22
    Austin, TX
    I've never experienced that. I've had several instances where I've passed the standalone "radar trailers", and each time it has flashed the exact speed that I was travelling.
  3. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    The sloped shape of the front end might make the Prius reflect slightly less than a boxy van, but it is by no means a stealth vehicle. Perhaps the speed sign in question had a very high threshold.
    Tom
  4. kenmce
    kenmce High Voltage Member
    1,528
    504
    NY
    They see me just fine.
  5. Barcelona Red Lass
    Barcelona Red Lass Sips gas like fine wine!
    227
    Sunny So.Cal!
    There's one of those stand alone signs near my neighborhood which tell you what your speed is. It always sees me, but it does tend to take a bit longer than when it sees my infiniti.
  6. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    radar works as expected on the prius.
    thank you for reminding me to pay my speeding ticket.
  7. patsparks
    10,664
    567
    Adelaide South Australia
    A front numberplate will increase the radar signature.
  8. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    I need to find this out with more testing but the other day my speedo showed 58mph but the radar thingy said 54. I know there is some margin of error but 4mph?
  9. CharlesJ
    CharlesJ Member
    467
    29
    38
    Monterey
    On stock tires? My previous car, rather old, analog spedo, was showing 3 miles less on radar than the spedo.
  10. qbee42
    18,058
    3,074
    Northern Michigan
    A HARM mounted on the roof rack will reduce the amount of detection time.
    Tom
  11. edthefox5
    edthefox5 Senior Member
    10,096
    4,804
    Clearwater, Florida
    They see me just fine too as well they should. The speed display's are puttin' out alot of power. My Bel65 Detector goes off way way before I see it. Hotter than a car radar.
  12. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    Maybe because you were driving in "stealth mode"? ;) If you don't want to stand out better not to be too bold;) (like your font)
  13. dbcassidy
    dbcassidy Toyota Hybrid Nation, 8 Million Strong
    1,581
    290
    Middlesex County, MA
    It depends, the RCS (radar cross section) of the Prius is indeed smaller than a box van. if a radar gun is emitting on both the Prius and the box van, the reflectivity signature of the van will trigger a reading on the radar gun.
    Under this situation, the Prius would be in "steath" mode.
    Dbcassidy
  14. AlphaTeam
    AlphaTeam Member
    643
    Earth
    Believe me, you CAN get hit with radar.
  15. taggart
    taggart Member
    249
    Yesterday, we were driving along a stretch of road that had an unmanned speed alert trailer. We had barely reached 40 mph. The sign said we were doing 77! The car in front of us registerd 42 and was not a Prius.
  16. hill
    8,158
    If one is coincidentally & legally transmitting at 440mhz at 50 watts or higher, the transmission can ... er, 'deflect' many radar signals. :p The junk devices sold to the suckers out there, only put out a few milliwatts, so they'e worthless. And if you DO transmit 50 watts on many bands, you better darn well be shielded from the signal.
  17. qbee42
    18,058
    3,074
    Northern Michigan
    I think a HARM on the roof rack is more effective, and it looks cool too.
    Tom
  18. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    Consider the angle first. The gun will only be completely accurate head on due to cosine error. In most cases the closer you are, the greater the angular offset and therefore the greater the error in your favor. Ten degrees should give less than 2% error, but 15 degrees works out to 3.4%, 25 degrees is 9.4% if I understand this correctly.
    A radar sign is not likely to be well calibrated and they tend to use older tech anyway (often X-band from what I pick up.)
    With regards to the OP it wouldn't surprise me if the Prius signature was smaller than average, particularly if the vehicle does not have a front plate.
  19. Celtic Blue
    2,224
    139
    Midwest
    Probably X band from what I recall of the sign signals. That stuff can be picked up several miles away (particularly if there is a very low gray cloud layer). I've seen this with the old X band guns used by plant security types as well. I don't know if they transmit a much stronger signal or if it is just really easy to detect from background.
  20. toxicity
    toxicity A/C Hog
    146
    Houston, Texas
    Isn't HARM an air-to-surface missile? I would imagine the resulting explosion of shooting the radar device might chip the paint on the Prius. Not worth it.
