No warning beep for headlights left "on"?
Discussion in 'Gen 3 Prius Main Forum' started by ES44AC, Sep 2, 2012.
  1. ES44AC
    ES44AC C.A.U.S
    319
    77
    I'm surprised that with all the other bells and whistles and beeps there isn't one to let me know I left my lights on.
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    Once you open your door, there's a default timer to shut them down in 30 seconds...at least that's the way it is on the 10s. You can have your dealer change it to "instant off" when you open your door.
    ES44AC likes this.
  3. kalome
    kalome Member
    411
    72
    Arizona
    2016 Chevy Volt
    I turn my headlights on and off manually. At first I was using the automatic lights, then one day it did not turn off automatically. I came back to my car after two hours and the headlights were still on. After that happened I never went back to using the headlights automatically.
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    OP, just an fyi as seen in your profile, your 2011 Prius is a model Two not II unless you live in Hawaii as I think there they used the roman numeral numbering system for 2011 as well. The rest of the US only used Roman Numerals for models in 2010.
    As also stated the lights are on a timer and should shut off after ~30 seconds. I can't recall off hand how, but there is something one can do which makes them not turn off like what happened to kalome. When I still had my 2010 (and my 2006 as well) I just turned them on and off as needed. Now for 2012 I have full true auto and just leave them on Auto.
  5. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    If you turn on your accessories after turning off your car, the headlights dont auto off.
  6. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Bingo.
  7. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    sLick415 is correct. You pretty much have to try to keep them on. :)
  8. ES44AC
    ES44AC C.A.U.S
    319
    77
    Hi phoneixgreg,
    I will try it and see if it works but the last thing I need is for it not to work and end up with no power :(
    thanks!
  9. kgall
    kgall Active Member
    984
    152
    Olympic Peninsula, WA
    Tiny correction
    My lights don't go off 30 seconds after I open the door (after turning the car off). The lights stay on as long as I have the door open--or any other door, including the hatchback.
    The lights go off 30 seconds after I close the last of the doors.
    I looked in the Owner's Manual p. 206, and in 2010 that was how it was supposed to work.
    I've never left a door open like this for more than a few minutes, so there may be a fail-safe for idiots who leave doors open (which I have done).
    P. 165 says that if you leave the car in ACC and the shifter in Park for an hour, the car will turn OFF. But by this time, the 12 V battery could be discharged, depending on what you have been using, the Manual says.
  10. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    Also, if you turn off and on the lights when the door is open, they should stay on....
