Noise coming from brakes when pressed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Osxarsam17, Oct 19, 2017.
  1. Osxarsam17
    Osxarsam17 New Member
    US
    can someone help
    52,385
    probably the brake actuator.
    jerrymildred likes this.
  3. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    It seems like there are a variety of sounds made by the actuators on various Prii. I can't think of anything else that would make continuous noise if you press on the brake unless there was some huge malfunction and it was squirting brake fluid on the pavement.
  4. 05PreeUs
    05PreeUs Senior Member
    1,097
    565
    MSP
    I must be deaf.
  5. Osxarsam17
    US
  6. bisco
    52,385
    ah, okay, that's different then.
  7. ChapmanF
    18,537
    What I hear starting at 0:18 is the usual stretchy noises from pressing the brakes hard, plus a little high-pitched squeak on applying the brakes or on releasing them.
    Just sounds to me like a place where some metal moving on metal could use a new dab of grease. It's a Gen 2, so I'd probably start looking at the rears (unless you're sure it sounds like the front, in person), just because the drum brake mechanism has more stuff to slide around.
    -Chap
