Noise coming from front driver side when turning Left
Discussion in 'Gen 3 Prius Main Forum' started by stephensprius, Dec 26, 2019.
  1. stephensprius
    stephensprius Active Member
    670
    226
    Minneapolis, Minnesota
    It's been happening a white, 2013 Prius with 98,xxx miles or so. When we turn left it makes a noise like something is rubbing against another part- not a terrible noise otherwise I would've taken it in a while ago. Any thoughts?
  2. stephensprius
    670
    226
    *** Perhaps this should be moved to the tech/troubleshooting section? My apologies.
  3. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    whoa, that is very very bad news.
    Time to trade it in for the new Prime, your pick Rav4 or Prius
    jk, might just be something rubbing in the wheel well.
    Have to get down there to check with wheel turned
    Or even the steering wheel.
    Is the noise outside or inside?
  4. stephensprius
    670
    226
    hahaha :)
    Noise is inside the cabin, Not sure about outside. It is quite literally the very first issue we have had with the vehicle outside of just the regular maintenance. Haven't even had to replace brakes yet.
  5. bisco
    52,725
    could be a bearing or cv joint as well
    Johnny Cakes likes this.
  6. stephensprius
    670
    226
    so do you think it's worth taking in, could it cause further issues to my wife's vehicle or are we ok to keep going?
  7. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    I have not read here on priuschat about this, but both my prius
    have some "feedback" when turning the steering wheel.
    Turn it slowly and you can hear something.
    not sure if is the electric steering or what.
    Heard from the cabin, and basically can feel it thru my hands too.
  8. stephensprius
    670
    226
    Oh, that is similar to what it is, I think. I just can't always remember it happening though.
  9. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    Dont jump to conclusions yet.
    That would cost you some chunk of change.
    Im sure they will find lots of problems that need to be addressed. :sneaky:
  10. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    I would say to start with jumping in the drivers seat, get it to "ready"
    windows up, no noise going on.
    and slowly turn steering wheel, see if the noise is the same.
    On my "c" I get it, but also some possible plastic on plastic noise.
    But last time I spent some time doing it, it just seems to be "electric" and not so much plastic rubbing.
    Hard to explain
    But I would also check the wheel well outside to make sure nothing is danglin' or rubbing the tire etc
    stephensprius likes this.
  11. Johnny Cakes
    Johnny Cakes Senior Member
    1,065
    789
    Virginia, USA
    Does the noise change depending on speed?
    Is there noise at all speeds?
    Have you cranked the wheel and checked for clearance?
  12. stephensprius
    670
    226
    Only at very low speed. Generally from a stop.
  13. Johnny Cakes
    1,065
    789
    Virginia, USA
    It would be interesting to walk along the car while someone else is driving to see what it sounds like from outside.
    Actually, if you could record it and post that might help everyone diagnose.
    At this point my wild guess is suspension.
  14. stephensprius
    670
    226
    I will try to do that tomorrow. Can I post a video on here? I’ve not done that before...
  15. dig4dirt
    dig4dirt MoonGlow
    1,153
    741
    Lancaster Co PA
    yeah you can post a video.
    Some people have trouble.
    If you have a youtube acct, you can also post it there, then link posted here will also work
