NOISE FROM UNDER HOOD ?
Discussion in 'Gen 2 Prius Main Forum' started by shar1950, Nov 17, 2007.
  1. shar1950
    shar1950 Junior Member
    merritt, bc canada
    I have this noise coming from under the front hood when I first start the car in the morning. It sounds like a bad bearing. What is spinning before the gas engine starts up ? Is therre any recalls ?
  2. Bob64
    1,540
    93
    Virginia
    Thats the coolant pump pumping hot/warm coolant out of the coolant thermos storage. You'll hear the same pump pumping hot coolant into the thermos for storage when you turn off the car.
  3. hyo silver
    hyo silver Awaaaaay
    15,261
    1,601
    off into the sunset
    Yes, that's normal. No need to worry about a bad bearing or a recall. You may hear a few clicks and a whirring noise, something like a home aquarium pump or a quiet air compressor, before it starts and after it stops. The gas engine is actually spinning before gas is added and it 'starts', but you probably won't hear that.
    Is the noise any different than when you first bought the car?
  4. Tideland Prius
    16,445
    Yeah either the coolant pump (if you press the POWER button) or the brake actuator releasing pressure (if you step on the brake pedal)
  5. biphnest
    biphnest Junior Member
    Share 1950 -
    The sound may or may not be normal. If it is a new sound then it is suspect. There are a lot of posts related to noisy coolant transfer pumps. Do a forum search for "coolant transfer pump".
