Noise going into gear
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Lildevil, Sep 30, 2023.
  1. Lildevil
    Lildevil Junior Member
    30
    Omaha, NE
    After my car has sat in the garage over night, I get a scratching/grinding sound after starting the car and putting it into reverse. Sometimes it's not very load, other times it can be quite loud. No lurching movement or anything like that. I am really baffled on what is causing it.
  2. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Brake pads scraping rust off the rotors?
    49,489
    yep, the rotors rust very easily with just a little moisture in the air. best to scrape it off slowly before you really need the brakes.
    Air_Boss likes this.
  4. Lildevil
    30
    Omaha, NE
    No, the car isn't even moving yet.
  5. bisco
    49,489
    does it happen whether the engine is on or not?
  6. Lildevil
    30
    Omaha, NE
    It doesn't seem to matter. I can hit the start button, and put it in reverse before the gas engine turns on, or sit and wait in park until the gas engine turns on, then put it into reverse and hear it. It will not do it anymore until it sits overnight.
  7. bisco
    49,489
    it shouldn't come on with the car not moving, but could it be the pedestrian warning system?
    watch
  8. Air_Boss
    3,952
    1,083
    New Yawk
    If the pads are rusted to the rotors, they will first have to break free.
