Noise going into gear
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Lildevil, Sep 30, 2023.
  1. Lildevil
    Lildevil Junior Member
    30
    Omaha, NE
    After my car has sat in the garage over night, I get a scratching/grinding sound after starting the car and putting it into reverse. Sometimes it's not very load, other times it can be quite loud. No lurching movement or anything like that. I am really baffled on what is causing it.
    49,489
    rusty rotors
  3. Lildevil
    30
    Omaha, NE
    The car isn't moving.
  4. Lildevil
    30
    Omaha, NE
    The car isn't moving, thank you.
  5. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Just placing the car into gear will load the pad/rotor rust bind and cause it to ‘break’.
  6. Air_Boss
    3,952
    1,083
    New Yawk
    Just placing the car into gear will load the pad/rotor rust bond and cause it to ‘break’.
  7. Mendel Leisk
    38,726
    How many miles?
  8. Lildevil
    30
    Omaha, NE
    257K
