Noise under the steering wheel on all 2008's
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by deval, Mar 14, 2008.
  1. deval
    deval New Member
    Washington DC
    Hello!
    I have a 2008 Prius and there is a grinding noise that comes from the steering wheel area. I bought this car brand new and it has done this from day 1. I was concerned and took it back to the dealer where I test drove 3 other brand new 08's that did the very same thing.
    So far the noise occurs without rhyme or reason. When the noise occurs, i have tried braking / accelerating and it does nothing to the noise. It comes on every minute to 4 minutes and stays for anywhere between 5 to 25 seconds. It happens sometimes in park and also happens sometimes after the car is turned off.
    Any one else have this (seeing how 3 other new 08's had this issue some of you may be experiencing this) Any one got this solved?
  2. Genoz World
    Genoz World ZEN-style living
    797
    La Canada
    hi DEVAL,
    i recently purchased my 08 PRII #6 about two weeks ago....NO WAY, this sound does NOT occur in my car. a grinding sound would drive me crazy.
    now, i'm certainly NO pro on this car, but if the others made it, it could be a bad BATCH of assembly??? i dont know.
    i'm just here to let you know that my 08 does NOT emulate the same sound. i wish you luck in fixing this.
    :flame:
  3. Patrick Wong
    18,200
    6,474
    The brake pressure accumulator pump makes a grinding kind of noise on an intermittent basis, when it operates. Try pressing the brake pedal repeatedly to see if you can hear the pump function.
  4. MJ Daniels
    MJ Daniels Member
    Timbuctoo
    I haven't paid close enough attention, but will on the ride home tonight.
    There has been an inordinate amount of sounds coming from under the hood during shut down. Kind of like a groaning sound, maybe coming from the gerbils catching their breath??? Anyway the sound sounds like it should be there and the car runs fine, so I haven't worried about it.
    Should I?
  5. Patrick Wong
    18,200
    6,474
    When you turn off the Prius, you will hear the engine coolant heat recovery pump running for several seconds, to pump hot coolant into the storage tank.
  6. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    It's the brake accumulator pump. The Prius has electrically assisted power brakes. It can't use engine vacuum like a normal car, because the engine turns off while the car is running. To get around this, the Prius uses an electrically driven pump to build pressure for the hydraulic brakes. It runs at random times, usually when you are pressing the brake pedal. Typically it runs about every third time you press the brake, but that's not an exact number. The pump makes a buzzing or grinding sound down in the driver's footwell.
    Tom
  7. rochesteruser
    rochesteruser Cruzin' in Rochester MN
    153
    Rochester
    My 2008 is silent.
  8. johnford
    johnford Old Junior Member
    105
    Malvern, AR
    My '08 has a strange scraping noise near the bottom of the steering column when I turn the wheel. I just assumed it was a piece of the cowal scraping. Was going to ask the dealer on my next oil change. It is not loud and the wife says she can't hear it..... jf
  9. qbee42
    18,058
    3,074
    Northern Michigan
    They all make this noise. Whether you notice it or not is more a function of the driver than the car. There is inverter noise, motor noise, noise from the ICE, brake accumulator pump noise, thermos pump noise, and the emissions leak test pump. Many also develop scratchy brakes from rust, since the friction brakes are only lightly used. The brake accumulator isn't very loud, so you might not have noticed it. It's just a little buzz or vibrating sound; to some it sounds like a rattle.
    Tom
  10. ze_shark
    ze_shark Junior Member
    SF Bay Area
    Speaking of noises, we have once experienced a tap-tap-tap coming from the passenger side of the dash. Would occur repeatably with ignition on, car rolling or not, engine running or not. Repeatable sequence with a tap-pause-tap-tap-tap-tap that would continue indefinitely.
    Only happened that day though.
  11. Jack66
    Jack66 Kinda Jovial Member
    766
    Stafford, Virginia
    I have a barely noticeable noise of the same type, but I can only hear it when the ICE cuts off and I am going very slowly. I consider the small noise to be something that just about every car has but you can't normally hear it in a regular car.
  12. Jack66
    766
    Stafford, Virginia
    Hopefully your noise is not caused by the same thing that caused cyberprius' noise in the same location [squeek squeek].
  13. Benny Leonard
    Benny Leonard New Member
    Akron, Ohio
    I have a three-month-old 2008 Prius (1700 miles). The steering noise--a kind of "grinding" or "sizzling" when torque is applied to the steering wheel and the wheel is in motion (car stationary, power on) seems to be coming from the gears in the electric-assist mechanism. As an engineering educator (over 30 years teaching electro-mechanical engineering design, among other things), I'm particularly leery about grinding gears--especially in the steering mechanism of a moving vehicle! After being told by the original dealer's service person that this was a characteristic of ALL 2008 models (implying that it was within Toyota's specs), I took it to another dealer's service department. They were quite surprised by the noise, as it doesn't seem to occur in earlier models. They replaced the whole steering column, including the power assist components, only to find that the same noise occurs. [Then they checked other 2008's on the lot and found that, indeed, they all have this "characteristic" noise.] There is no TSB and certainly no recall that anyone's heard about. The guess is that Toyota may have changed suppliers for '08. The noise seems to be coming from either the idler gear on the electric-motor shaft that drives the ring gear or the planetary gear set itself.
    This worries me.
    Cheers,
    Benny.
  14. 13Plug
    13Plug Active Member
    581
    104
    2013 Prius Plug-in
    The 08 I test drove had a sort of buzzing (small electric motor) type noise coming from the dash. It did it at random. I didn't worry about it because I knew I wasn't buying *that* car.
    The 08 on it's way to me was built last month so we'll see when it arrives if it makes that noise. There are a lot of noises that are "normal" on the Prius that aren't normal on old-fashioned gas-guzzlers (non-hybrids) LOL.
  15. kevinwhite
    kevinwhite Active Member
    331
    199
    Los Gatos Ca
    My 2006 had a noise that sounds like this - I assumed it was the steering actuator or slip-rings to connect signals to the steering wheel.
    The noise faded over a couple of thousand miles and I haven't heard it since.
    kevin
  16. lefat1
    lefat1 Fat Member
    1,476
    47
    Sunny S. Florida
    mine is silent except for the normal shut downs, pumps and gerbils going to sleep
  17. qbee42
    18,058
    3,074
    Northern Michigan
    My 2006 makes no noise when steering.
    Tom
  18. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    I'm just turning 6 months on my '08 and I don't recall a noise. It is possible I suppose that a supplier was changed mid year. BTW, if I now hear a noise like you described I'm going to be pissed at you for pointing it out because it will drive me nuts. :p:D
  19. alanh
    alanh Active Member
    1,175
    99
    Phoenix, AZ
    My 2007 doesn't make any noise steering either. It does make the usual collection of weird noises after it's shut off.
  20. Kremtok
    Kremtok Smug Alert!
    100
    74
    Homer, Alaska
    I've also noticed the noise that the original poster described. To me, it just sounds like an electric motor turning on and off, so I never really worried about it. Part of getting used to this car has been getting used to all of the strange noises it makes as well as the relative lack of noise when compared to 'conventional' cars.
