Noise when turning
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Bwrx, Mar 15, 2014.
  1. Bwrx
    Bwrx New Member
    Everytime I drive the car after it has been off and sitting for a while (over night or while I'm at work) and I make a 90 degree turn I hear a noise similar to a pebble bouncing around the wheel well. It only happens on the first turn and then it doesn't make the sound again until the car has set a while.
    It sounds like the noise is coming from somewhere in the steering column or under the dash... Like a tiny screw, ball bearing/BB, or small pebble is resting on top of something and when I turn its falls. I guess the sound could also be described as a "plinking" sound... like something small is falling then bouncing around for a second or two.
    Anyone else experience this or know what it is?
    Thanks
  2. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    ISS problem? Can you feel a tiny little clunk in the wheel?
  3. Bwrx
    Bwrx New Member
    Do you mean when turning? If so, sometimes when turning its not completely smooth, feels slightly bumpy like an electric motor cogging or like something is slightly tugging on the steering wheel... It'll feel like that without making the plinking sound... The steering also may be making a slight intermittent creaking sound but I've only heard that in a parking garage and haven't determined if its something in the car or just the tires making noise on the cement.
    What's ISS?
  4. mediahound
    mediahound Active Member
    903
    155
    SF Bay Area, California
    I was told that is normal. The Prius uses an electronic steering motor rather than traditional hydraulic power steering. The motor has a particular feel and a bit of a sound when in use.
    The 'plinking' sound you are hearing sounds like a different sound however.
