noise
Discussion in 'Gen 2 Prius Main Forum' started by chuckyjean, Nov 27, 2010.
  1. chuckyjean
    chuckyjean New Member
    Wisconsin
    What is that noise the Prius makes after it is shut down? I'm sure it is suppose to do what it is suppose to do, I'm just curious what the noise is. Thanks.
  2. Hal W
    Hal W New Member
    872
    53
    Grand Forks,B.C. Canada
    I believe its the inverter cooling pump your hearing. Err err err. H
  3. Patrick Wong
    18,200
    6,479
    You are probably hearing the coolant heat recovery pump. It runs for several seconds upon cold engine startup and frequently also runs upon shutdown.
    The pump is moving coolant to and from the coolant heat recovery system canister, which stores ~3 liters of hot engine coolant. The idea is to speed up cold engine startup to reduce exhaust emissions during engine warmup.
