Noisy Powertrain after Transmission Service
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by vsavatar, Oct 8, 2023.
  1. vsavatar
    vsavatar Junior Member
    Livonia, MI
    2015 Prius v wagon
    I have a 2015 Prius v with 142k miles on it. I first had the transmission fluid changed at 65k miles and then again at 140k. Both trans services were done at the dealership. After the most recent one, I noticed that my powertrain is noisier than it was previously. I can't tell if it's the engine or transmission, and the sound isn't what I'd call particularly unusual, except for being louder than normal. It only happens when driving and is more pronounced at higher speeds. I've had no problems shifting gears or with it slipping at all. Any ideas as to what this might be and how to correct it?
  2. rjparker
    rjparker Tu Humilde Sirviente
    7,975
    4,716
    Texas Hill Country
    No gears to shift as the planetary gears are constantly engaged. Maybe a wheel bearing?
