NOISY TRANSITION TO BATTERY MODE
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by joe fortner, Jun 23, 2015.
  1. joe fortner
    joe fortner New Member
    new jersey
    2002 Prius
    I'm looking at a 2007 Prius I've never had one before so I posted in the General section with a few questions. From what I have read and from the responses I've got, the transition from gas engine to battery power should be unnoticeable. the car I'm looking at is anything but. I thought the car was stalling. the transition was very noticeable. It seemed as if there was a slight delay for the battery drive to kick in. It only did this at stop lights and stop signs etc. Is this a major issue or possibly just an adjustment?
  2. JC91006
    16,489
    8,402
    Drive another to compare, walk away if it's bad after comparing
  3. andrewclaus
    andrewclaus Active Member
    993
    324
    Golden, CO
    My ICE will often "stutter" and run on a bit when shutting down when the vehicle is not moving. I understand it's designed to run on as long as possible to burn off all possible hydrocarbons to lower emissions, and this is normal. It was disconcerting the first time. It is silent though. If you have audible noise, something may be wrong.
    It will also sometimes hesitate on acceleration in battery mode if the battery is mostly discharged. If I have a full charge, no problem at all. With a large electrical load (like A/C) it will be more noticeable.
    49,608
    so, you're sitting at a stop, the ice shuts down, you press the go pedal, and it takes a moment for the car to start moving? or, it starts moving on the electric motor, but takes a moment for the gas engine to fire up?
  5. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    with the age of the car Id say the motor mounts are worn that's what you feel when it changes from gas to electric
  6. joe fortner
    new jersey
    2002 Prius
    I think the best way to describe it is compare it to a regular car. It feels like when I pull up to a red light or stop sign the motor stalls. Ya know how a motor just dies out. I don't think its the motor mounts though. And compared to the other 2 Priuses I have ever test drive, this is way different. Something isn't right. But is it a minor thing or a major thing??? At this point I'm inclined to walk away.
  7. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    Once every drive cycle the engine does the idle test. When the idle test happens car idles couple of second and then the engine is shut off. When this happens system kind off stalls the engine on purpose.
    So if it only happens once its normal. If it happens more or all the time you have problem maybe throttle plate just needs cleaning maybe something else.
  8. joe fortner
    new jersey
    2002 Prius
    It happened around 4 or 5 times in the course of a 15 minute test drive.. Made me think "Oh crap, the car just died.* Then the display showed it went to battery mode and we kept going. I know its not normal. The other Prius I test drove was so smooth I didnt know it had even changed modes....and that was an 05.
  9. bisco
    49,608
    i always feel my engine shut off when i come to a stop, if it was running. the only way it would stay running is if it hasn't reached operating temp.
  10. dolj
    dolj Senior Member
    7,710
    3,903
    Wellington, New Zealand
    It is possible that you can get this ("idle dance") happening more than once per drive cycle if the ICE cannot maintain the temperature, it will drop back to stage 3b and once this happens, it will need to do the "idle dance" to transition back to stage 4.
    If something is wrong, then it is probably at the minor end of the scale but ultimately if you gut feel is that something is wrong, you need to just walk away from it.
