noisy transmission, louder when turning left at highway speed
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by gen 2 owner, May 9, 2022.
  1. gen 2 owner
    gen 2 owner Junior Member
    ontario
    Hello.
    My prius is a 2005 model.
    All my fluids have been changed last year, engine oil, inverter coolant, engine coolant and transmission fluid.
    About a month ago the car is making more transmission noise on the highway, during braking you can hear the speed of the car going lower thru the transmission noise.
    There is sort of a rubbing sound when you make a left turn around a bend on the highway.
    Today i lifted both wheels and spun them and also turn the wheel left and right and there is no rubbing or abnormal sound coming from the wheels.
    Recently i had the car rust protected and the cv boots were intact, no rips.
    Everything under the front end looked good.
    Do gen 2 prius have a problem with the transmission or electric steering, the car has approx. 180.000kms on it, so not too much mileage for a 17 yr old car.
    Any help would be appreciated, before i have to take to my mechanic or dealership.
    Thanks.
    49,402
    not as a regular problem, but anything is possible at that age.
    still, i would suspect something in the front suspension and have it looked at by a good shoppe before moving on to the tranny.
    it can be difficult to determine where noises are coming from. when you raise the car, taking the weight off of the suspension, it changes everything.
  3. edthefox5
    edthefox5 Senior Member
    10,096
    4,805
    Clearwater, Florida
    What did the trans fluid look like last year?
    And how much trans fluid did you put in?
    The G2 trans is probably the most bullet proof trans ever made.
    I ran Redline D6 in mine for 14 years trans never made a sound.
    Changed 3 times.
    Thete have been a few reports of chain failure and a bearing failure on this site but not common.
    You didn’t mention who did the trans fill hopefully not the dealer.
    If it was me I would get the car fairly level and open the side fill hole and see what the fluid level is it should be at the top of the hole.
    If not that’s not good #1.
    Then pull the trans fluid and try to measure the volume should be 4 quarts.
    Also check how much metal is now on the dump bolt magnet and then put the fluid in a wide mouth container and put it in the sun see ifyou see any nonferrous metal in it. Mine never had any metal on that magnet just a little soft mush.
    Also check there’s no trans fluid leaking at the cv joints where they enter the sides of the trans that’s kinda common.
    Have you tried getting up to speed like 60 miles an hour
    And put the trans in Neutral and see how it sounds?
    Good luck.
  4. mr_guy_mann
    mr_guy_mann Senior Member
    3,443
    1,496
    NJ-USA
    If there is a noise when moving, and it changes some when making a (gentle) turn in one direction but not the other, then a wheel bearing is near the top of my list of suspects.
    ydpplqbd and slow_wagon like this.
  5. Another
    Another Senior Member
    1,802
    511
    Naples, Florida
    Any chance the recent rust proofing work did something. What did they do?
  6. slow_wagon
    slow_wagon Junior Member
    27
    Upstate NY, USA
    I would second the wheel bearing suggestion. Can you post a video?
    ydpplqbd likes this.
  7. bisco
    49,402
