Nokian Tires Rolling Resistance Test Video - neat...
Discussion in 'Gen 3 Prius Fuel Economy' started by donee, Nov 27, 2010.
  1. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi All,
    Came across this video by Nokian Tires:
    7 people like this.
  2. Mendel Leisk
    41,118
    One run with unnamed "market leading ecologically designed summer tyre", one with their Hakkapeliitta R studless snow tire, and finally a run with their unnamed prototype tire:
    Interesting, but I wish there were more specifics in this test. Is tire #3 their EnTyre? What is the "market leading" tire, Michelin Energy Saver A/S? Too many unknowns: their marketing department seems in disarray, especially considering their limitted availability in North America.
    We used Nokian WRG2 as winter tires on our previous '06 Civic Hybrid: they imposed at least 10% mileage penalty, compared to the stock Bridgestone Insignia SE200_02, or the Ecopia EP20 we replaced them with.
  3. donee
    donee New Member
    2,956
    198
    Chicagoland
    Hi Mendel,
    Yep, its not full of specifics. The test was done the 3 March, 2010. So, presumably, tire three was a hopped-up laboratory version of the eNtyre as the eNtyre was released this summer. They say in the end that the full suite of features in the Tire #3 was not ready for the real world.
    This is the kind of test that can be easily replicated though. Say at Hybridfest. Which is probably the only way we are going to get hard info between brands. I also liked that they used a 2010 Prius for the test.
    Even the video below although more specific, has no information how poor the original tire compound was in comparison to other brands:
    So, what is more deceptive, the company that comes out and tells you up front it was an experiment. Or the company that tells you their new tires are better than their old, but gives no information as to how poor the old standard tires were?
  4. Mendel Leisk
    41,118
    I wonder if some cars are more prone by tire changes, more likely to have mileage tank with install of snow's: within a week of getting our 2010 Prius we put Michelin X-Ice on, with no apparent impact, though this is purely seat-of-pants, not much of a mileage log to compare with. ;)
    Yeah, I guess Nokian could at least have identified that base line summer tire. They seem a good company, but with mixed marketing. In Vancouver (and maybe right across Canada) Kal Tire is the source, no one else carries Nokian.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I doubt the "summer tire" is the Michelin ES A/S. It's an all season tire.
  6. Tideland Prius
    16,531
    It's Canada-wide.
    This is why I bought my Nokians from Washingston state. They're half the price Kal-Tire was charging.
  7. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    I run Nokian WRG2s on my Prius. The mileage is the same as it was with the OEM Goodyear Integrity tires and with Micheline MXV4+ Energy tires. New tires take a bit to break in, but after that all three of these tires produced very similar mileage.
    Tom
  8. normdugare
    normdugare New Member
    Los Angeles and Astoria
    I am PROBABLY going to go with those soon. My 2010 has 13k miles after 5 months, but over the next five months I will be making bi-weekly commutes between Los Angeles (where the winters can be anywhere from 40 degrees and rainy to 95 and sunny) and Astoria Oregon (where the winters tend to stay between 20 and 45), and we all know how good OEM tires are.
    There is likely to be little snow on the ground, but probably ice at times in Oregon. My problem is that I can't use winter tires in southern California.
    On the plus side, since Astoria is a Finnish town, I can get Nokians there easily. Just not sure if I should, or if so which ones.
    Suggestions are appreciated.
    Thanks,
    Norm
  9. orange4boy
    orange4boy Member
    231
    44
    Vancouver BC
    2003 Prius
    I have WRg2s on my 2003 and they are excellent in the rain and snow. I'm up in BC. They wear pretty fast though at treadwear 400. They corner like performance tires and are very quiet. They get very good mileage once worn in. The treadwear is my only minus on these but I tend corner fast and the fronts are the ones that are wearing faster. I should have got an alignment when I replaced my transmission though so it could be that it's out.
    Five stars.
    The rears are still at 8 mm fom 10 mm after one year. The fronts are at 5 mm.
  10. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    I was VERY happy with the Nokian i3 tires. I almost prefer them over the Yokohama dB Super E-Spec (because of better wear). I'm tossed up between the 2 but the Nokians definitely looked nicer. :)
    If the new tire is better than the I3's then I would seriously consider them for my next purchase!
  11. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    Where do you get Nokian tires in Astoria?
    alfon
