Nokian WRG2... Highly Recommended!
Discussion in 'Gen 2 Prius Main Forum' started by biff_debris, Jul 9, 2008.
  1. biff_debris
    biff_debris WOOF!
    81
    Prescott, WA
    I just had a set of Nokian WR G2 tires installed and have to say that my initial impression is very positive! Compared to the Goodyear Assurance TriplTreds that they replace, steering seems much easier, they feel much lighter, seem to be quieter and handle very well on dry roads. I can't wait to find out how they do on snow and ice. I've already noticed an increase in mileage compared to the previous tires, but, again, time will tell.
  2. Rotorhead
    Rotorhead New Member
    79
    Kalamazoo, MI
    Re: Nokian WR G2... Highly Recommended!
    That is one hot looking tire!
  3. Tideland Prius
    16,151
    great to know! I have the first Gen WR on mine.
  4. Dunlin
    Dunlin Senior Birder
    Grays Harbor, WA
    I have about 5500 miles on my WR g2 tires so far. I replaced the original Integrities with these, and so far the MPG is slightly better than the originals. I went with the 185/65 15's, but I think that the steering is slightly more vague than with the originals. The traction and cornering is vastly improved, however.
    Arnie
  5. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    That's good news. :)
    I'm going to try out the Nokian i3 later in the Fall.
  6. Silver 2008
    Silver 2008 Junior Member
    71
    Idaho
    How is the stability on the highway? I get blown around quite badly by crosswinds with the stock tires.
    The snow can get deep here in Idaho, and I have heard that the OEM tires are downright dangerous in the snow, so I am looking real hard at the WR G2's.
    The low rolling resistance is a big factor in my decision. How is the noise on concrete highways?
    Thanks in advance,
    Mike
  7. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    What do they cost?
  8. bac
    bac Active Member
    863
    52
    Pennsylvania
    Your friend:
    Google :D
    ... Brad
  9. lenjack
    804
    114
    Pennsylvania USA
    Brad...I appreciate Google and use it daily, but I don't think it will tell me what the OP paid. :)
  10. biff_debris
    biff_debris WOOF!
    81
    Prescott, WA
    I paid $165.08 per tire at a Tire Factory outlet. Rather steep, although I've seen them as low as $121 online.
    Problem is, if you have trouble with them, the on-line retailer will be happy to help if you send them back. I had TripleTreds delivered by UPS and installed by a guy who pointed out that, had I bought them from him I'd get all of the side benefits, but since I bought them elsewhere...
    Anyway, my MPG went from around 48 to over 53 by switching to this tire. I'll be looking forward to the ice and snow season.
    Here's the result of my first tank on WRG2s...
  11. jdenenberg
    jdenenberg EE Professor
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    You can get a price from:
    Nokian Tires - Winter Tires, Snow Tires and much more from the Tire Factory
    I bought my Nokian WR tires from them 25,500 miles ago (4 for less than $400) and am very pleased with their performance. They replaced my Michelin MXV4+ (went 55,000 miles which replaced the original GY Integrity tites (went 44,500 miles). See the attached spreadsheet to compare their MPGs (The Nokian WR and WRg2 are real LRR tires).
    JeffD
  12. Silver 2008
    71
    Idaho
    I would be very appreciative if someone who owns a set of these tires would try to answer my two questions about them.
    1. How is the stability on the highway? (I get blown around quite badly by crosswinds with the stock tires.)
    2. How is the noise on concrete highways?
    Mike
  13. jdenenberg
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Mike,
    They are much better than the GY Integrity tires (It's hard to be worse).
    The WRs can be somewhat noisy due to their agressive tread design. This is what gives the great snow/ice traction.
    The WRg2 tread is agressive on one edge and standard touring on the other edge so they are a compromise - A little quieter but a little less snow traction.
    The Nokian i3 should also do well and be quiet, but it is a strictly summer tire and I have no real data.
    JeffD
  14. Silver 2008
    71
    Idaho
    Thanks Jeff. I was looking specifically at the WR-G2 tire. I have had WR's on my Maxima and have liked them, but they seem to wear out kind of fast. (25K for me)
    I am glad the G2s will be quieter, but dissappointed to hear they may not get the same traction in the snow as the regular WRs. Overall however, there is not another tire with all the attributes I want. The low rolling resistance is very high on my list.
    I think I am going to buy a set of the G2s. We get some pretty nasty winters here in Idaho, so they will definitely see snow and ice. I will let the rest of you know how they fare.
    Thanks for all your help.
    Mike
  15. PeterPrius
    PeterPrius Hers is a 2009 Prius, non-SKS
    48
    Lakewood, Colorado
    Sorry for dragging up an old post. I have the WRG2's on my 2005 Prius in Colorado. They give me far better handling than my old 4WD ever did.
    We just had a nasty, fast 5 inch dump that turned the roads into an ice rink, but I didn't have a single issue. Cornering was superb. The most important attribute is slush and the WRG2s are superb!
  16. dhoward
    dhoward Junior Member
    Massachusetts
    I put a full set of these tires on my 2007 Prius last Sept. I have now had a chance to use them in snow. For the first time since I bought my Prius I now feel confident driving it in snow. The tires grip the road better then any all season tire I have ever owned. Granted I have never spent as much for tires as these but they are well worth the cost. I notice that even when the Traction control kicks in it is much less severe then with the integrities. My mileage has not really changed one way or the other. I do a lot of short drives now a days which does not help much. But I love these tires.
  17. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    +1 on the WRg2 tires. As for cost, I paid more for my previous Micheline MXV4+ Energy tires. The Micheline tires were great tires, but so far the WRg2s seem even better.
    Tom
  18. gak27
    gak27 Prius, Take Two
    117
    Akron, OH
    +2 on the WR G2s...for the short time they've been on the car and on the road (1 month hiatus for accident repairs) they are noticeably better and reassuring in all kinds of weather. Our street doesn't get plowed much and the Prius now gets out quite readily. The VSC still kicks in at times but is much less aggressive (similar to dhoward's observation); they also move a good deal of snow (noticed this while wife was driving up our street)...paid around $125/tire out the door...
  19. qbee42
    18,058
    3,074
    Northern Michigan
    That sounds about right. Mine cost a smidgen over $500 installed for the set of four, including taxes.
    Tom
  20. jdenenberg
    3,852
    1,845
    Trumbull, CT
    2020 Prius
    LE AWD-e
    When I stated (in an earlier posting) that the WRg2 would have somewhat lower traction in snow than the earlier WR model, it was based on the less aggressive tread design. You all should remember that the WR had better traction in snow than many real snow tires and now that I have WRg2 tires they are still quite good in snow. These are great tires.
    JeffD
