Non curt hitch for the PIP
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by EvanB, Aug 4, 2014.
  1. EvanB
    EvanB Junior Member
    39
    Phoenix, Arizona
    2014 Prius Plug-in
    Hello,
    It seems that for the curt hitch the same model for the lift-back works on the PIP
    However for draw tie and the hidden hitch they specifically call out the PIP and the unsupported car.
    Any one have ideas as to why if the undercarriage is the same? Anyone try this hitch on a pip?
  2. john1701a
    john1701a Prius Guru
    12,754
    5,245
    57
    I've been using a Curt hitch on my PIP for over a year now, on a number of long trips carrying bikes. It's worked great.
    I recommend getting that and have no idea what the heck could be the issue with the other brands.
    JBumps and retired4999 like this.
  3. vvillovv
    vvillovv Senior Member
    3,623
    1,274
    NY
    I looked under the PiP the other day to see how the hidden hitch would fit after watching a video.
    I can't say for sure if this is the reason or if the hidden hitch will absolutely NOT fit.
    But the undercarriage panels on the drivers side where the hitch attaches to the tiedown ring mount
    look like the undercarriage panels may hang too low to allow the hidden hitch to mate to the mount point.
    The curt looks like it's vertical mount bars are longer then the hidden hitches vertical mount bars are.
    If someone could measure the length of those bars we'd have a better idea.
    #3 vvillovv, Aug 6, 2014
  4. EvanB
    EvanB Junior Member
    39
    Phoenix, Arizona
    2014 Prius Plug-in
    Thank's for looking. I tried to look but with no other Prius for comparison it was moot. I wrote to hidden hitch and got a generic "it will not fit" message.
  5. vvillovv
    3,623
    1,274
    NY
    Did you look under your car on the drivers side where the hitch attaches?
    It's way up there with a 4 inch long 2 inch wide hole in the belly panel.
    The hitch attaches to the frame where the tow ring is bolted to the frame on the drivers side.
  6. EvanB
    EvanB Junior Member
    39
    Phoenix, Arizona
    2014 Prius Plug-in
    I could look but since I have a PIP how can I tell if that hole is deeper than on a non PIP. Also the low's are still near 100 so spending time in the garage is not my fav pastime this time of year.
  7. vvillovv
    3,623
    1,274
    NY
    Guess you'd have to guess just like me.
  8. slonis888
    slonis888 New Member
    lubbock tx
    The hidden hitch that came off my 2006 gen 2 prius is too short (lengthwise) to reach from frame to frame on my 2010 gen 3. I held the old gen 2 hitch up against 2010 underside and it just WOULD NOT WORK. I ordered another specifically for the 2010, 2011.
  9. bisco
    49,408
    anyone pulling a trailer on ev only?
  10. markabele
    5,084
    1,782
    Nebraska
    On my recent Tesla test drive the rep said he knows of a few people that put a hitch on a Model S. He of course had to follow that up with, "we don't recommend you tow with a Tesla."
  11. bisco
    49,408
    i understand the disclaimer, because there is towing, and there is TOWING. i'm thinking a lightweight utility trailer, to take to the dump, so i can get rid of my truck. is it more work than having another 600 lbs of people in the car?
  12. markabele
    5,084
    1,782
    Nebraska
    You wouldn't think so...physics-wise at least
  13. vvillovv
    3,623
    1,274
    NY
    Thanks Slonis888, I'd taken a look at the connection points under my vehicle and was guessing that the length of the hidden hitches attachment brackets were not long enough for the crossmember to clear the under panels around the tow hook on the 14 PiP. Next time I get a chance I'll measure the width also.
    bisco - Yes, towing in ev, but only in the winter.
  14. kurbmaster
    kurbmaster Junior Member
    46
    24
    I've towed a lot in ev mode and in hv mode. Have a hidden hitch. Have 3 rail motorcycle trailer that I tow a small motorcycle and the three rail trailer converts to a box trailer with a plywood conversion. Car towed great. On a recent 200 mile trip with about 500 lbs I averaged 44 mpg. No need for a pick up truck for me. I don't tow anything heavy just bulky.
  15. Redpoint5
    Redpoint5 Senior Member
    1,026
    508
    Portland, OR
    I towed an 1800 lb load of soil on a lightweight 4x8 HF trailer a few days ago. Went to the yard in EV mode, but switched to HV mode when loaded down just so I didn't hold traffic up too much. Once up to speed, I switched back to EV. I should have taken note of the trip MPG, but it was likely 80 or so considering minimal use of gas.
