Non Ethanol Gasoline
Discussion in 'Gen 2 Prius Main Forum' started by williaeh22, Aug 30, 2008.
  1. williaeh22
    williaeh22 Junior Member
    Satellite Beach, FL
    I have recently discovered, with the help of the local newspaper, that BP Service Stations (not all) are carring an additive to their gasoline called "Invigorate". It is a non ethanol additive. I was under the impression that 10% ethanol was required by federal law back last May 2007. Evidently it is a state requirement, not federal, because Florida has some BP station carring this additive.
    I have searched on BP's web site for what the additive consists of, but found no information listed. The owners of the BP service station that I have purchased gas from, swear there is not any ethanol present in their gas (no stickers on pump). My mileage (one tank) seems to bear this out.
    Have anyone else noticed this change, in BP stations, in other states?
  2. rigormortis
    rigormortis Active Member
    1,340
    26
    san jose, ca
    im not an expert about this at all, and i could be totally wrong...
    their is no federal law that requires specifically ethanol.. it only requires an oxygenate, and after stations stopped using mtbe, they switched to ethanol.
  3. markderail
    markderail I do 45 mins @ 3200 PSI
    2,260
    163
    Pierrefonds (Montreal) Quebec Canada
    Petro Canada I've discovered adds Ethanol at the pump - as get this - engine cleaner.
    There's a tiny sticker on the pump that says there is as much as 10% ethanol.
    I was wondering why I was having such a low MPG rating since I've moved. From home, the nearest station is a Petro Canada.
    I've switched to Shell, Esso or Ultramar. I now get over 10% more kilometers.
    Like a jump from 510-525 kilometers for 30l of gas, to now over 600 kilometers.
  4. richard schumacher
    7,664
    1,046
    United States
    Ethanol is an engine cleaner. I hope you're not driving 10% farther to get a 10% improvement in fuel economy...
    Invigorate claims to be an engine cleaner additive package:
    bpinvigorate.com | About Invigorate
    and so like all of them is to some extent a marketing gimmick.
  5. Marty111
    Marty111 New Member
    New Port Richey Fl.
    I am most concerned with the long term problems that may arise from using fuel with ethanol. I've heard (can honestly say I haven't read owners manual cover to cover) that premium fuel should not be used. There are a few gas stations by me that sell premium gas "without" ethanol. It's mainly for boats, but I run it in my Harley. What about running it in a prius?
  6. uart
    uart Senior Member
    4,220
    1,211
    Australia
    It wont hurt, but if it costs more than about 4 percent more then you're not likely to gain anything.
    I use Ethanol-free petrol here because it only costs about 2% more. I only get a few percent better mileage, so if it cost too much more (say 5%) I wouldn't even bother.
  7. JamesBurke
    JamesBurke Senior Member
    1,222
    493
    27
    Morgantown, WV
    Similar thread going http://priuschat.com/forums/gen-ii-prius-fuel-economy/94348-real-gasoline-not-ethanol-4.html
    Canada has different gas regs than the US.
    From my post #21 on the other thread.
    Chevron Motor Gasolines Technical Review. Well written for the non engineer.
    Chapter 1 contents:
    1 • Gasoline and Driving Performance . . . . . . . . . . . . . . . . 1
    Volatility
    Vapor Pressure
    Distillation Profile
    Vapor-Liquid Ratio
    Vapor Lock Index
    Driveability Index
    Volatility Specifications
    Antiknock Performance
    Octane Number Requirement
    Power
    Fuel Economy
    Factors Affecting Fuel Economy
    Fuel Economy Road Test
    Other Performance Factors
    http://www.chevron.com/products/prodserv/fuels/documents/69083_MotorGas_Tech%20Review.pdf
    Top Tier Gasoline
    "TOP TIER Detergent Gasoline is the premier standard for gasoline performance. Six of the world's top automakers, BMW, General Motors, Honda, Toyota, Volkswagen and Audi recognize that the current EPA minimum detergent requirements do not go far enough to ensure optimal engine performance."
  8. qbee42
    qbee42 My other car is a boat
    18,058
    3,079
    Northern Michigan
    Gasoline with up to 10% ethanol is not harmful to the Prius. Horror stories about ethanol come from using it in engines not designed for ethanol. For newer cars this is not an issue.
    Tom
  9. john1701a
    john1701a Prius Guru
    12,818
    5,303
    58
    That's extremely hard to believe at this point, especially since the entire state of Minnesota has been using nothing but E10 for well over a decade now. If there was a problem, why haven't my friends driving Classic model Prius had any trouble? For that matter, why haven't I? After all, I drove 118,185 miles in my Iconic model before trading up to the 2010.
    And be aware that your concern is also your very first post on this forum. That immediately raises suspicion...
