Non IPOD Compatible MP3 Players
Discussion in 'Gen 3 Prius Audio and Electronics' started by TopJimmy5150, Oct 21, 2009.
  1. TopJimmy5150
    TopJimmy5150 Junior Member
    55
    Gillett, PA
    I did a search on this and was not able to find anything relevent.
    Is there a list of Non-IPOD Mp3 players that are compatible with the Prius' USB port. The documentation specifies IPODs and "USB Music Devices" (I think). I would like to find the cheapest selection that will allow me to use the NAV/Touch screen to select songs.
    I own several SANDISK SANSAs that don't work with the Prius USB port.
    Thanks in advance.
    -Jay
  2. BruceG
    BruceG Junior Member
    San Jose CA
    USB flash drives work well. I don't think any other non-iPod players work.
  3. TopJimmy5150
    55
    Gillett, PA
    You mean like a USB Thumb Drive? I have tons of those things laying around, so that would be awesome.
  4. lamontcranston
    lamontcranston Umbra Tenet
    212
    17
    Southern California
    I am interested if that's what you mean. I make data CDs of MP3 files but if I could plug in a 16GB flash drive that would be better. (Of course I'd have to get the USB upgrade first...)
  5. DickPhillips
    DickPhillips Member
    89
    58
    Mount Vernon, WA
    I'll have to try this. My 2010 arrived 11 Sep and the Nav system did come with the IPOD connection. If I understand this string of posts right, I can copy MP3 files from my PC to a thumb drive, plug that drive into the IPOD connection and then see the file names on the Nav screen?
    I have burned CDs that play fine in the music system but there is little info given on the screen and it does not have song titles, only info like file # 131, I guess telling me that it is about to play the 131st MP3 file on that CD. I do kind of like to have more info displayed- guess that comes from all the info that is available attached to those files that I keep in iTunes and then burn onto CDs.
  6. lamontcranston
    212
    17
    Southern California
    I have the basic radio and on mine if you push {TEXT} it will give you the song title or the artist if it's an MP3 or WMA encoded data CD. Have you tried that?
  7. DickPhillips
    DickPhillips Member
    89
    58
    Mount Vernon, WA
    I have the other radio that goes along with the Nav system but it does have a button labeled Audio and that does cause the display to change from the map to one that does show the song title, singer, etc plus quite a bit of more information. Thanks for the suggestion!
  8. TopJimmy5150
    55
    Gillett, PA
    It works! I loaded up my 8gb flash drive and tried it. Works like a charm...somewhat. It's difficult to navigate across folders. It brings up the first 5 and the scroll bar is grey out so you can't get to any more than the first 5. You can sequentially scroll through the folders, and when you hit Select it will bring up the current folder plus the next five, but again...no more using the up/down arrows on the screen. I did discover that you can hold down the up/down arrows on the steering wheel and it will go to the next folder. Not great, but better than nothing.
