nonsteel belted tires
Discussion in 'Gen 3 Prius Accessories and Modifications' started by John Puccetti, Mar 4, 2013.
  1. John Puccetti
    John Puccetti Junior Member
    Ventura Ca
    Does anyone know of a nonsteel belted tire for the plug-in Prius? Kevlar is what I have heard is very good and does not emit emf.
  2. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    EMF? Electromagnetic Fields? Unless you are passing a current through your wheels, no magnetic fields will be generated...
    49,433
    Elf Made Farts
    josh2008 likes this.
  4. Tracksyde
    Tracksyde Member
    1,429
    761
    So Cal
    I thought the same.. so I had to google it
    source:
    Radial tire - Wikipedia, the free encyclopedia
    (direct source: https://prof.hti.bfh.ch/fileadmin/home/mik1/Magnfields_HPJ_revision.pdf)
    But even so, maybe someone smarter than me can explain to me why it would matter?
    F8L likes this.
  5. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  6. rekniht01
    rekniht01 Junior Member
    Knoxville, Tennessee
    Yeah. I'm looking for some tinfoil belted ones. Also a tinfoil roof wrap. because you never know. ;)
  7. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    I believe some BFGoodrich tires have Kevlar belts in them as well.
    Here's the question: If you rotate back to front, and then cross the two fronts when moving them to the rears, wouldn't the rotation in the opposite direction "de-EMF" the tires?
  8. Corwyn
    Corwyn Energy Curmudgeon
    2,171
    659
    23
    Maine
    So you have a plug-in Prius and are worried about EMF from the tires? Not the battery bank, or the high voltage inverter, or the big motors?
    xliderider and xpcman like this.
  9. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    I guess we need to start shopping for non radio tires now? :D
  10. xliderider
    7,869
    3,116
    Honolulu, HI
    Bullet resistant tires = cool. ;)
  11. kithmo
    kithmo Couch Potato
    2,404
    2,773
    47
    South Yorkshire, UK
    No, you can magnetize ferromagnetic material (iron/steel) by subjecting it to a constant single direction magnetic field, but to demagnetize it you have to subject it to a gradually reducing AC generated (i.e. pole reversing) magnetic field.
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    That would be less dangerous than a tinfoil hat, because if you wear a tinfoil hat too tight it will cut off your circulation and make you paranoid. :D
  13. Former Member 68813
    3,524
    981
    US
    Interesting reading. I learned something new.
    Considering that low level magnetic fields are harmful after all:
    Exposure To Low-level Magnetic Fields Causes DNA Damage In Rat Brain Cells, Researchers Find
    I will try not to drive with my head next to the wheels.
