Nontechnical guy new here
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by RobKuhn, Nov 6, 2018.
  1. RobKuhn
    RobKuhn New Member
    Pelham, NY
    Hi ...
    I recently had to replace the Body ECU on my 2012 Prius C two. I'm wondering where it is in the car - in order to determine whether something stupid I did (actually, something I didn't do) might have contributed to the failure. Another conversation established that in the 2013 Prius (model?), it's behind the dashboard on the driver's side. I'd love to hear that it's in the same spot in my 2012 C - as that would make it less likely that what I did caused the failure. Thanks for your help.
    Thanks!
    Rob
  2. ztanos
    ztanos All-around Geek!
    3,339
    1,149
    40
    Cumming, Georgia
    Very little changed from the 2012 to the 2013. Mid 2013 had a fuse box jump terminal tab added, but as far as I know, that's about the only change.
  3. Leadfoot J. McCoalroller
    7,176
    6,727
    Pennsylvania
    2018 Prius c
    Due to practical considerations (wire length, space available) the body computer of nearly every car made is more or less in the same spot- under the dash, close to the steering column & pedal assembly.
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    This is intriguing.
    What WAS it that you did ?? :whistle:
    I believe that computer board is commonly called the Body Control Module, or BCM.
  5. rjdriver
    rjdriver Active Member
    406
    168
    Rhode Island
    Here's a drawing showing placement in the Prius (part #12). The page doesn't mention the C specifically, just Prius 2012-2015, but it probably wouldn't take too much digging around under the dash to confirm the exact placement. And as ztanos said, it's very unlikely the 2012 and 2013 are any different.
    ELECTRICAL COMPONENTS.
