Noob question about upgrading stock Prius II sound
Discussion in 'Gen 3 Prius Audio and Electronics' started by Vincent Detour, Oct 23, 2016.
  1. Vincent Detour
    Vincent Detour Junior Member
    45
    Toronto, ON
    Hi folks, we're picking up our 2013 Prius II tomorrow! (only 37,000km on it) and in test driving I noticed that the stock audio pretty crappy.
    I'm not an audiophile but I'd love to upgrade to something better without laying out a lot of $...
    Is the stock amp sufficient to run some half-decent speakers? I mean, is there an easy, pop-out, pop-in solution to just replace the speakers and get a decent boost, or is that unrealistic?
    We'd be running music from our Iphone 6s, itunes or streaming, or listening to the built-in radio.
    Do folks generally replace everything, or...?
  2. Rebound
    Rebound Senior Member
    3,964
    2,613
    Portland, OR
    There's a sticky thread with all the instructions you need here:
    2010 Toyota Prius model II Head Unit Upgrade | PriusChat
    I think the upgrade which improves sound the most is to replace the 6x9 front door speakers. I bought some good-quality JBL's, but nothing super-expensive and esoteric. Bass and treble both improved very noticeably with this. Follow Spider-Man's instructions carefully. In particular:
    1) Buy a Pop-rivet gun. A good-quality one.
    2) Carefully read how Spiderman re-used the bracket of the stock speaker as a mounting bracket. He describes it for the rears, but it also applies for the fronts. So you do not need to buy a speaker mounting bracket.
    3) Consider installing a little bit of sound deadening material, such as Dynamat. You don't need to go nuts and cover every square inch with the stuff. Even a little on the inner and outer sheet metal will deaden vibration substantially.
    I next replaced the dash board "squawkers" with better speakers, but it's a lot more work and less improvement results. But you are replacing some complete garbage speakers, so there is gain.
    The rear door speakers did not improve much. I think it's because I used 6 1/2" low-profile speakers. The cones don't move much. From the front, at least, I notice little quality from the rear speakers. Maybe different rear speakers, non-low-profile, would sound better, but I didn't test anything else for fit. I think they'd fit, though.
    #2 Rebound, Oct 24, 2016
