Noob Question - Sorry! No daytime running lights?
Discussion in 'Gen 3 Prius Accessories and Modifications' started by Luvs2Run, Jul 15, 2009.
  1. Luvs2Run
    Luvs2Run New Member
    Dallas
    Does the G3 really not have DRL?
  2. fgp
    fgp Active Member
    503
    169
    daytona
    2023 Prius
    Re: daytime running lights
    your post did not complete but you seem to be asking if gen 3 has daytime running lights. no, but. you can do like i do. turn on your lights once and then forget about it. everytime you turn off the car AND exit they turn off automatically. no one turns left in front of me. i do the same thing with my motorcycle but with it i keep the headlight on highbeam at all time.
  3. Luvs2Run
    Luvs2Run New Member
    Dallas
    Perfect - This is how I roll today, so thanks for clearing the air. I see the mods for auto headlamps and was curious!
    Thanks!
  4. DeanFL
    DeanFL 2010 owner - 1st Prius
    1,015
    355
    Leesburg Florida USA
    I'm a DRL proponent. Have been in many countries (incl Canada) where they are mandated. Bottom line, DRLs make a vehicle more visible even in sunlight. But I find them valuable to better see those inconsiderate drivers who do not turn their lights on at dusk or the weather turns dark quickly.
    So I have begun to leave my driving lights / tail lights on all the time. As you mention, they automatically turn off 30 seconds after closing the door. And, the V has very cool driving lights - the upper band (not the lower round LEDs) in the att picture.
    I will take the minimal power hit.
    This make have been asked here before - is there any circuit mod being developed by PC Gurus to automatically turn on the front driving lights when the car is 'Ready'?
  5. hawkmoon77
    hawkmoon77 New Member
    233
    162
    Tampa, FL
    After just having installed the automatic headlights, the mod you described would be VERY easy and cost about 6 bucks.
    My standard disclaimer applies here. I am not a mechanic nor am I qualified in any way to perform auto work. Below is not my advice, but rather a description of what I would do. Please use caution with this or any modification, and please do not in any way rely on my information, but rather do your own diligence and proceed at your own risk.
    All I would do is to get one automotive grade 12 volt relay and socket. I would wire the relay to the headlight harness under the dash (see my thread on autoheadlights to see how I did it). The relay would close pins 20 and 12 on that conenctor (L47 see attached picture) The wire colors are light blue and green. Then, all I would have to do is connect the other two wires from the relay, (the ones that control the relay on/off state), to a 12V+ source when in ready mode and the other to ground. That's it. Daytime running lights.
    If I didn't want the highbeams on, but wanted all other exterior lights on, then I would connect pins 18 to 12.
      File size:
      14.4 KB
      1,084
  6. gonzfence
    gonzfence New Member
    I bought a Toyota Prius 2005 in Miami three months ago. In two months I am going back to Canada, and I would like to import my vehicle. To pass the Canadian inspecion I will need to have DRLs. I went to a Toyota dealer, and they told me that my car doesn't have DRLs and it is not possible to install it. But I see you have multiple solutions for that.
    Does anybody have tryed to install DRL in a Prius? I would like to know how to do it and the price for that.
    Thank you very much for your help,
  7. Fred Hiltz
    Fred Hiltz New Member
    Shelburne VT
    Re: No daytime running lights
    A search for "running lights" turns up several relevant posts. Among others, I described my experience installing an aftermarket kit in a G3, not significantly different, in this thread: http://priuschat.com/forums/gen-iii...aytime-running-lights-brake-light-pulser.html
    Better check the kit's web site for the current price.
    Fred
  8. PixelRogue
    315
    57
    US
    Ok. So you can turn on your headlights manually (leave them on all the time.) There is a mod where you disable the 30 second delay. That is certainly a viable solution.
    My question, here, is that the dash dims way down when the lights are turned on...the dash goes into night time brightness mode. Is there a way to disable so you can keep the headlight on while maintaining bright dashboard during the day?
  9. qbee42
    qbee42 My other car is a boat
    18,058
    3,073
    Northern Michigan
    Roll the dimmer switch all the way up, past the click. This forces daylight mode.
    Tom
