Normal corrosion on a 10-month old HV battery?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Chris HV, May 11, 2017.
  1. Chris HV
    Chris HV Member
    64
    36
    East Coast, USA
    2018 Prius Prime
    Long-time visitor... first post in this amazing community!
    We own 4 Prii (two gen2, two gen3), currently working on the HV batt of our 2004 with 164K. Here is the background. Car got Xmas lights in Spring 2016. I pulled the traction battery and replaced the one module that was out of whack. which I got from a rebuild hybrid shop in NJ, re-installed and sure enough got Xmas lights a week later (have since read and learned a lot here!) Bought a rebuilt pack with 6 months warranty from same shop, installed it and all seemed fine..
    Just 10 months later that pack went bad again, after only 3K gently driven miles. One bad module diagnosed via mini VCI. Pulled HV again, bought 2 modules on Ebay, currently working on the PITA process of recharging cells, etc.
    I have a curiosity question for the more experienced members here. Does the corrosion you see in the attached pics seem normal for a 10-months old rebuilt pack?
    51,155
    welcome!
    i have no experience, but that doesn't look too bad. the thing is, there are rebuilt packs, and there are rebuilt packs. and even the best of them are iffy.
    Raytheeagle likes this.
  3. jadziasman
    jadziasman Prius owner emeritus
    1,355
    487
    District 6
    I'm going to assume that you didn't (or weren't permitted to) open the case before the most recent rebuilt pack was installed.
    IMHO, the corrosion is several years old. It seems the rebuilder did little more than replace the bad modules and re-balanced them as assembled for this pack.
    edthefox5 likes this.
  4. Chris HV
    Chris HV Member
    64
    36
    East Coast, USA
    2018 Prius Prime
    Yes, I un-crated and installed the pack as-is, there was a $400 core fee which I only got back way after I shipped it (it was a bear getting it to UPS too...)
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,831
    Clearwater, Florida
    The rebuilder did exactly what u did to your previous battery, replaced s module never bothered cleaning it and shipped it. Whack a mole battery rebuilder. That corrosion is extensive and very old. That's original corrosion too not corrosion back on a previous cleaned battery. Hope you didn't spend a lot of money.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Those bus bars appear to have impressions from a nut with a ridged or serrated surface. I've never seen an OEM battery with that style fastener. At least they used new fasteners (y). I would not expect to see that level of corrosion buildup in 10 months, but I also don't have a lot of experience with the NJ climate's impact on bare copper bars either. But, I have a battery pack that I've had on equalizing for 6 months (experiment) and the beautiful shiny heavy gauge copper wire I installed is no longer shiny at all and has green buildup on it. Soooooo.........I'll withhold judgement as to whether they were cleaned or not.
    SFO and Andyprius1 like this.
  7. ericbecky
    ericbecky Hybrid Battery Hero
    4,381
    3,242
    Madison, Wisconsin
    Clearly that rebuilders chooses not to clean off the buss bars.
    Whenever buying a "rebuilt" battery it is Buyer Beware if you are not getting it from a reputable company.
    Can you please share the name of the place in NJ. Are they still in business? Inquiring minds want to know.
  8. Andyprius1
    Andyprius1 Senior Member
    2,327
    859
    Cool CA
    Before installing a replacement pack, all contacts should be cleaned including all male and female components. Generally every contact should be coated with a light coat of Vaseline. We have some great HV battery experts at PC, they can assist with all the aspects of troubleshooting and replacement and balancing. It's quite involved, requires special equipment and cannot be done overnight. Find a HV Bat restorer with at least a 1 yr warranty. Just replacing individual module(s) is not recommended.
  9. Andyprius1
    2,327
    859
    Cool CA
    Yea, that green mold seems almost alive, I believe it conducts also, in a short circuit way.
  10. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    That is typical corrosion. And not that bad compared to many packs I've seen.
    A large percentage of older cars are driving around with this much corrosion or more.
    SFO and Raytheeagle like this.
  11. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Next time apply some No-OX to all shiny parts and they will stay shiny.
    Shiny is attacked very quickly.
  12. edthefox5
    10,096
    4,831
    Clearwater, Florida
    Use No-OX instead of vasoline It is designed to protect metal from galvanic corrosion.
    Andyprius1 likes this.
  13. Chris HV
    Chris HV Member
    64
    36
    East Coast, USA
    2018 Prius Prime
    Thanks for the early replies, here are a few more pics of the other side exactly as I found it. Thoughts and feedback appreciated!
  14. bisco
    51,155
    pristine.
  15. Andyprius1
    2,327
    859
    Cool CA
    Ty Ed like that No- Ox ...idation can be bought At ???
  16. Andyprius1
    2,327
    859
    Cool CA
    The condition of the outer casing is not critical. All elec. contacts must be dry and clean ..except for No-Ox.
    Don't know, I assume that's totally conductive, I know Electra-Clean is.
  17. Chris HV
    Chris HV Member
    64
    36
    East Coast, USA
    2018 Prius Prime
    The NJ climate is typical East Coast, very humid compared to Sacramento. Those nuts do have a serrated face that bites into the connector bars, lightly plated with possibly nickel, but so unevenly and deeply corroded that it's hard to believe they were installed 10 months ago. Anyhow, am I crazy in thinking that the nuts were pretty much the only part of the rebuild that was properly handled?
    ericbecky likes this.
  18. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    Chris HV, interesting to see that some of the modules appears to be broken.
    Looks like you got some real castoffs there.
    Looks like the kind of bad modules that might get sent to recycling.
    Too bad people can't know the quality of what they are buying. The, unfortunate, assumption is that all rebuilds are the same. This is a great example of how they are not.
    I'd like to use at least one of your photos as education for others. Is that OK?
    At least now you have an inkling what you are dealing with. Time to quantity how bad things are and decide how/if to save it.
    Is this company still in business?
    I hope not.
    As always, feel free to call if you want to chat or bounce ideas about how to tackle the situation.
    Andyprius1 and Chris HV like this.
  19. Chris HV
    Chris HV Member
    64
    36
    East Coast, USA
    2018 Prius Prime
    They are. See pic (more detailed post to come.)
  20. ericbecky
    4,381
    3,242
    Madison, Wisconsin
    Falcon??????
    Noooooooooooooooooooooooooooooooooooo!
    Sorry to hear that.
    Well, now it all makes sense why you are having to deal with all these issues.
    Another example I'll have to add to my wall of shame.
    That. said, I guess it did last as long as their stated warranty. So they upheld their end of the bargain.
    SFO and edthefox5 like this.
