Not able to get high a/c fan output while driving.
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by JeremyAndACat, Jul 16, 2024.
  1. JeremyAndACat
    JeremyAndACat New Member
    Tucson, AZ
    When I start my 2011 Prius I can usually get the highest fan speed going while it's in park but once I start driving it will put out air closer to a low or medium speed and I can hear/feel it fluctuating up and down. If I put the car back into park I can eventually get it to put out high speed air but it takes a few minutes. I suspect it's a bad blower motor and/or resistor but the fluctuating up and down only while driving isn't a symptom I'm seeing others experiencing. Any idea what this could be?
  2. JeremyAndACat
    Tucson, AZ
    I should add that after about 25 minutes of running, the A/C seems to work normally.
  3. JeremyAndACat
    Tucson, AZ
    And sometimes if I set the fan to the lowest speed for about a minute, the issue will be resolved.
  4. ChapmanF
    18,533
    Is the "auto" light on, or off?
    Does the blower speed bar graph on the display go up and down with the actual blower speed, or is the bar graph staying at full?
    Prius hasn't ever used a blower resistor, though gen 1 and 2 used a separate electronic controller that mounted in the air duct the same way an old-school resistor would, and sometimes people call it that.
    Gen 3 moved that controller into the motor itself, so there isn't even the thing-people-called-a-resistor. At least that reduces the number of parts to think about.
  5. JeremyAndACat
    Tucson, AZ
    The highest fan speed fluctuates whether it's in auto mode or not. The fan speed goes up and down incrementally with the bar graph but the speed still fluctuates up and down.
    That actually is good news about the resistor, thanks!
  6. ChapmanF
    18,533
    I can't quite tell what you mean here. When you notice the fan speed fluctuating up and down, is the bar graph changing with it, or is the bar graph holding steady?
  7. rjparker
    rjparker Tu Humilde Sirviente
    10,491
    6,581
    Texas Hill Country
    I suppose you could have something jamming the blower like leaves or nesting material. Check the cabin filter.
    Perhaps one of the blend door or air routing servos is failing or slipping.
    A long shot would be the system is limiting the power to the AC system based on engine overheating.
    Techstream or other scanners could verify some of the air handler and compressor functions.
  8. JeremyAndACat
    Tucson, AZ
    I checked and cleaned the cabin filter but while it was removed I noticed the fan speed was still fluctuating up and down.
    I'll look into the blend door and air routing servos.
    I'm guessing it's not overheating since it takes around 20 minutes or so for the fans to finally kick up to a fast speed and then it's generally fine until the car is turned off for a couple of hours. Also I have an OBD scanner and I've never had any codes that suggest overheating.
    I thought maybe it was the auxiliary battery since it's fairly old and I've been having random intermittent electrical issues like windows going back down while I'm trying to put them up and the bluetooth disconnecting and then reconnecting about once a week. The battery looks like it's in good health though.
  9. JeremyAndACat
    Tucson, AZ
    One other thing that I remembered was once during the last winter here I turned on the heat and it wouldn't pump out hot air until I turned the HVAC system off and on a couple times, then is started pumping hot air immediately. At that point I hadn't had any fan speed issues and I thought it was just a weird electrical thing like the windows/bluetooth.
  10. bbrages
    bbrages Member
    167
    47
    St. Louis
    Probably need a new blower motor
  11. JeremyAndACat
    Tucson, AZ
    I replaced the blower motor and that seems to have done the trick. The spinning cylinder seemed fine so I'm guessing it was the resistor. Thanks for the help!
    bbrages likes this.
  12. ChapmanF
    18,533
    A gen 3 doesn't even have the part people used to mistakenly call a resistor. It just has a single blower motor with speed control built in, which appears to be the thing you changed that solved your issue.
