Not driving for 6 months
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by nicoj36, Oct 9, 2015.
  1. nicoj36
    nicoj36 Active Member
    495
    158
    Hello fellas,
    I'm going overseas for 6 months and I am leaving the beloved Prius in storage. Would the battery stay alive for 6 months without being started? Should I worry that when I come back, it wouldn't start on me?
    Any inputs/suggestions would be appreciated.
  2. jamesalbonn
    jamesalbonn New Member
    florida
    2015 Tesla Model S
    Hi nicoj36,
    Prius have 12 volt battery.it may work for 3 three months without driving. From my experience 6 months without driving may cause issues...
  3. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    High Voltage Traction battery will hold for 6 months, 12v will not unless you disconnect it.
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Yes, fill the fuel tank, put a little more pressure in the tyres than usual (42 PSI front and 40 Rear will do), and either disconnect the 12V battery or put a "battery tender" on it. You can connect the battery tender on the "boost point" under the hood. If you disconnect the 12V battery do so at the negative terminal. Make sure all interior lights are off.
    The "traction battery" should be fine for 6 months. It is completely disconnected when the car is off. It will loose some charge but should have plenty left to get the car going again.
  5. bisco
    49,478
    put a little stabile in the fuel tank.
  6. mrbigh
    3,686
    699
    Long Island, NY
    As already mentioned, this are legit pointers for storage purposes
  7. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
    use the marine one/
    way stronger/
  8. David Beale
    5,963
    1,981
    Edmonton Alberta
    Use it if you like, but I have never had any problems with 6 month storage without fuel stabilizer. I'd think about using it with a year or longer storage.
  9. StarCaller
    1,246
    697
    just for the peace of mind.... ;-)
    SCH-I535 ?
