Not Engaging Gear
Discussion in 'Gen 3 Prius Technical Discussion' started by Mark777, Mar 10, 2012.
  1. Mark777
    Mark777 Junior Member
    Fullerton CA
    2010 Prius 52K miles . not enagaging in Drive or Reverse ,Engine is not starting either. Got Message - Put in park , All the lights are ON , in the Dash .
    Help ! ! ! ! :)
  2. GrumpyCabbie
    GrumpyCabbie Senior Member
    6,722
    2,121
    45
    North Yorkshire, UK
    You sure it's in Ready mode? Press the brake a bit harder when pressing the Power button.
    Have you had work done on the car and inadvertantly run the 12 volt battery down? Is the trunk hatch shut correctly? Do you leave the car for long periods or drive it daily?
    When you try and engage Drive or Reverse does the car beep beep beep at you?
    My inexperienced money is on a flat or low 12v or dodgy switch on the brake pedal.
    Try powering all the windows down and up together at the same time to see if the 12v is ok. If they're very very slow, then your 12v is shot. If they're all normal speed then it's ok.
    Any other info you can give might help.
  3. BARSOMAUTOMOTIVE
    BARSOMAUTOMOTIVE Prius Expert Whittier CA.
    Whittier
    The 12 volt battery must be fully charged, verify that. Also if for some reason, lights were on for a long time, may had drained your battery. The low volt and the HV battery must always be charged otherwise it will not start.
    51,140
    a lot of 10's have had short 12v battery life due to sitting on dealers lots for months waiting to be sold.
  5. vday
    vday Member
    312
    Israel
    It has happened to me as well
    Try "shutting down" the car and start the process again.
    After once or twice it should be fine.
    It appears that the computer needs a reboot every so often :)
    Hope it works
  6. john1701a
    john1701a Prius Guru
    12,797
    5,279
    57
    With the Iconic model, pressing the Power button a fraction of a second prior to the Brake pedal being fully pressed would cause that lockup. It took us a long time to figure out it was the result of rushing. It was always assumed something else was wrong.
    Hold the Power button for awhile, to kill the system. Then slowly trying the startup again, but this time ensure all activity with your foot is complete before using your finger.
  7. David Beale
    David Beale Senior Member
    5,963
    1,987
    Edmonton Alberta
    Well, he appears to own a 2004 GII, posting in the GIII section. So it's understandable he's a bit confused. ;)
    It's most likely the 12V battery is low. Is it the original one? If so it's at end of life.
  8. GrumpyCabbie
    6,722
    2,121
    45
    North Yorkshire, UK
    More confused that than. He quoted it as a 2010 with 50k miles so I'm guessing he hasn't bothered updating this side profile.
  9. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    1) Turn the vehicle "off."
    2) Make sure all the doors are closed.
    3) Start it up.
  10. kithmo
    kithmo Couch Potato
    2,404
    2,774
    47
    South Yorkshire, UK
    +1, I had this message and unable to select gears when I hadn't shut my driver's door properly.
  11. qbee42
    qbee42 My other car is a boat
    18,058
    3,076
    Northern Michigan
    The other possibility is a bad brake light switch, or mis-adjusted switch. The ECU needs to sense brake application before switching to Ready.
    Tom
  12. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    I've had similar messages when I first got my Prius. I never did figure it out (it did "go away" eventually). Likely the battery was abused at the dealership prior to my ownership.
    However, I did have a number of 12V battery issues almost from the getgo with my car. Pressing the brake (seeing the brake lights going on) and pushing the start button, but the car not going into Ready mode was a common occurence.
    Replacing with an Optima has resolved this issue.
