Not enough oil causes the overfill-related CELs too.
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by galaxee, May 14, 2007.
  1. galaxee
    galaxee mostly benevolent
    9,810
    465
    MD
    DH had a classic prius owner show up yesterday with a check engine light and codes P3191 and P3101. she hadn't changed her oil in over 10k miles and it was just over 2 qts low.
    he added oil and the codes went away. the owner didn't have time to have an oil change done, apparently.
    just a heads up with all the oil-level debate/mayhem around here.
  2. tochatihu
    tochatihu Senior Member
    9,045
    3,528
    Kunming Yunnan China
    2001 Prius
    Very interesting...I would first wonder where the 2 quarts went! At least a few Prius change synthetic engine oil on 12 k intervals and oil level reductions have not been reported. I am certain that DH would not let it leave the bay with oil leaking from the pan or seals.
    If the oil is blowing by the rings, would this eventually interfere with catalyst function (tho one might anticipate different DTCs from that).
    Did he notice if the throttle butterfly was heavy with soot? I understand that in extreme cases this can lead to 3191.
    My atttention is on matters other than oil level (or pressure) per se because the way for that to cause a no-start is not at all clear. As far as the car can tell, ultra-low oil (from the ECU's perspective) would seem to be like disconnecting the oil pressure sensor - does that cause P3191?
    Also if by any chance this really old oil is still available, I would like to obtain a sample for chemical analysis. Too much to hope for, right?
  3. galaxee
    9,810
    465
    MD
    the customer made it clear she was to be in and out of the shop in short order. he didn't even have time to drain the old oil before she wanted it back, just top it off. the codes did go away after he topped off but he didn't have time to do any more thorough of an investigation.
    he expects that the engine was burning oil but without time to actually look at the thing...
    she did say she was at least 5k over the oil change interval, and who knows- she may have been changing at the recommended 7.5k interval, which would put more than 12.5k miles on the oil.
  4. TonyPSchaefer
    14,816
    2,497
    66
    Far-North Chicagoland
    Just in/out. Don't investigate? No time?
    Excuse me?
    I hope those were two very expensive quarts of oil.
  5. Mr.Vanvandenburg
    1,027
    350
    2020 Prius Prime
    There are people who do not ever change oil from new, never check it, think the red oil light MAY mean don't drive, and find it annoying to have the annoying oil added. I have known such people. My theory is their father's always nagged them to change the oil, and they are out to prove father wrong. These cars are later called "one owner" trade ins.
  6. bmillerbiop
    bmillerbiop New Member
    FYI - at about 100K miles, my 2004 Prius also started losing/using oil - about one quart between the 5K oil changes (which I did religiously). Disappointing and a bit odd, since the remaining oil continues to retain the golden, semi-translucent character. You'd think it would turn brown-black if it was burning oil. Could it be getting sucked up somewhere (PCV tube or something)?
  7. daveleeprius
    daveleeprius Heh heh heh you think so?
    429
    Seattle
    <div class='quotetop'>QUOTE(bmiller @ May 14 2007, 03:13 PM) [snapback]441874[/snapback]</div>
    Wow. Our 1991 Corolla has 115k and doesn't burn oil at all, no leaks either. Same with my old 1988 Civic that was rear-ended. Engines were as tight as a drum. Hope our 2007 Prius doesn't start using oil at 100k.
    Dave
  8. morpheusx
    morpheusx Professor Chaos
    1,555
    81
    Akron, OH
    <div class='quotetop'>QUOTE(DaveLeePrius @ May 14 2007, 04:18 PM) [snapback]441881[/snapback]</div>
    All combustion engines burn a little oil, if you look in your prius manual you can find a detailed reason why.
  9. galaxee
    9,810
    465
    MD
    <div class='quotetop'>QUOTE(bmiller @ May 14 2007, 04:13 PM) [snapback]441874[/snapback]</div>
    well if the oil is still such a nice golden color, DH suspects it's leaking somewhere rather than burning. oil seals do wear- they are maintenance items.
