Not going into Drive
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by Gerard Rivers, Feb 18, 2023.
  1. Gerard Rivers
    Gerard Rivers New Member
    Los Angeles
    So today i changed the Spark Plugs. Before changing them, I disconnected the battery. After replacing the spark plugs. I put everything back, and connected the battery at the end. It gave me a pcs, abs, and some other symbols. After searching some videos, some stated it could be a bad battery. Took the battery to autozone and was told it was bad. Bought a new one, connected to the car and still no luck. Does anyone have any suggestions? I will try to upload pictures in the future.
  2. rjparker
    rjparker Tu Humilde Sirviente
    9,589
    5,888
    Texas Hill Country
    First, no need to disconnect the battery to do plugs or most any work.
    Did you touch, move or remove the orange high voltage disconnect in the back? Did you try to jump the Prius with another car?
    Tim Jones and Air_Boss like this.
  3. Gerard Rivers
    Los Angeles
    I did remove the high voltage in the back. And after getting the new battery, i had it tested and was at 12.3 V
  4. Air_Boss
    Air_Boss Senior Member
    4,139
    1,154
    New Yawk
    Be sure the HV interlock is fully re-seated and re-locked.
  5. rjparker
    9,589
    5,888
    Texas Hill Country
    Often people don't make the last hv connect step
    Its not required to be removed for any routine maintenance
  6. Gerard Rivers
    Los Angeles
    So i just did step 2, and yes i didn't realize that was nes
    Air_Boss likes this.
  7. Gerard Rivers
    Los Angeles
  8. bisco
    51,140
    A lot of people don’t
  9. Gerard Rivers
    Los Angeles
    Ok so drove the car. Went to autozone to return a product when i turn the car back on, the Hybrid System warning light was gone. THANK YOU ALL FOR YOUR FEEDBACK AND TIPS
    bisco and Air_Boss like this.
  10. Tim Jones
    Tim Jones Senior Member
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    Get the entire EGR System Cleaned.................
    And read up in here about all of the other stuff that is going to go bad....
  11. Gerard Rivers
    Los Angeles
    Is a clogged EGR the reason why coolant drains so fast?
  12. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    If you are loosing water you have a Blown Head Gasket.................
  13. Gerard Rivers
    Los Angeles
    From the coolant reservoir? Would that give me an error code? What other symptoms would I experience?
  14. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    If you are loosing water and no puddles on the ground you have a Blown Headgasket.
    Look for white smoke out tailpipe
    Running really bad at startup
    Use caution engine can hydrolock and blow a hole on the side of it.
  15. Gerard Rivers
    Los Angeles
    Do you have a link or a video on hpw to change the headgasket?
  16. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    No I don't. Google or utube it.
    Have you ever torn a engine apart?
    It is very labor intensive.
    Costs about $400 in parts and get the head checked out at a automotive machine shop.
  17. Tim Jones
    1,742
    562
    SE Texas
    2011 Nissan LEAF
    Or possibly pay someone $1500 to $2000 to do it.
