Not ready
Discussion in 'Gen 3 Prius Main Forum' started by Vastolrd, Aug 30, 2024 at 2:21 PM.
  1. Vastolrd
    Vastolrd New Member
    Today
    Poland
    Hi
    I have a problem with the Prius 3 2010.
    I replaced the steering columns. After the replacement, the car fired up normally, I did a test drive (without the driver airbag). After the ride, I parked, tightened the steering wheel and put on a airbag. Now the car does not want to go into ready mode (it turns on with the lights on dashboard). There are no errors in the computer.
    I noticed that the immobilizer light flashes all the time even with the ignition on.
    12V battery is brand new.
    I try to disconect 12v battery and main battery fuse.
    49,712
    no errors in what computer?
  3. ChapmanF
    15,890
    Do the brake lights light up in back as you're trying to go READY?
  4. Vastolrd
    Vastolrd New Member
    Today
    Poland
    They were so
    U0142
    U0155
    B1801
    B1504
    But all marked as historical. Their cleaning didn't change anything and didn't reappear.
  5. Vastolrd
    Vastolrd New Member
    Today
    Poland
    Yes.
  6. Tombukt2
    Tombukt2 Senior Member
    9,661
    1,688
    Durham NC
    But I'm not sure that there's anything in the steering column that would have to deal with your immobilizer You're immobilizer wasn't doing this before the steering column change and does that mean when you say steering column is that also the electric motor piece that's a whole piece or does that come apart and there again I don't think any of this has to deal with the immobilizer that's interesting that you're immobilizer is looking for something or the remotes not speaking to the immobilizer maybe You have a red light that lights on your key fob?
