Not sure how to set up bluetooth
Discussion in 'Gen 2 Prius Audio and Electronics' started by Karah, Aug 8, 2014.
  1. Karah
    Karah Junior Member
    Tried to sync car to phone Bluetooth w/o success.
    Any advice?
  2. eblade
    eblade Junior Member
    70
    Plymouth, Michigan
    Can you be a little more specific as to what you did, and what happened?
  3. Karah
    Karah Junior Member
    Thanks for your response eblade,
    Well. I pressed all the buttons on the dash-mounted screen & on the steering wheel & checked phone to see if it was picking up a tooth to connect to. While the car was in motion, or rather, not in Park.
  4. eblade
    70
    Plymouth, Michigan
    To pair the phone (this is from memory, may not be correct) you have to select Phone -> Settings -> Connect, and then search from the phone's Bluetooth setup menu. You can't pair while the car is in motion.
