Not sure what Prius to buy
Discussion in 'Newbie Forum' started by FirstFlight, Oct 9, 2010.
  1. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I've spent the better part of the past two days researching these forums, along with information on the internet. I think I'm more confused than when I started.
    I need a new car and was looking to buy a hybrid. I went from the Civic, to the Inisght, and settled on the Prius. Here is my dilemma:
    I commute 66 miles round trip to work each day and drive 880 miles a month to see my kids. That's 2200 miles a month, not to mention trips to the gym, grocery store, etc.
    I was thinking of buy a used Prius but decided a new one is probably the better choice for me. In my research, I've learned some really interesting things. As I'm sure most of you on here know, they have a conversion kit to plug in the Prius (many types). They have a solar panel for the Prius. And now, in 2012, they will have an OEM version of a plug in type Prius.
    My question is, given the miles I drive, what is the best option for me? I wouldn't be able to plug in at work, only where I live.
    49,528
    there really is no 'best' option. unless you want a plug in conversion kit, (it won't pay for itself) get a 2010 prius. great prices right now, $4,000. off msrp. unless you want to wait for a factory plug in. probably won't be able to get one for 2-3 years.
  3. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    The only thing that concerns me (mostly because I don't know exactly how the system works) is that if I drive right off of the highway, will the battery be fully charged, or most people say 80%? It's not good to leave a battery at say 50% for a long period of time.
    This is why I was looking at the solar panel option. It's expensive at $3500 but at least it would keep the batteries charged. And, if it wouldn't make up the difference in gas, it may save a year or two on the expensive battery.
  4. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    You have more research to do
    The solar panel does not charge the battery at all
    it powers a fan to circulate the air inside the car when it is off
    We got the sunroof because the wife likes a lot of light in the car
  5. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    You misunderstood me. I've done my research. It does charge the battery. See this: www dot solarelectricalvehicles dot com (can't post the link because don't have more than five posts)
  6. Paul58
    Paul58 Mileage Miser
    1,126
    125
    Atlanta
    The solar panel doesn't charge the battery, it just runs a small fan that circulates the outside air through the car to keep the inside temp closer to that of the outside temp.
    The computer controls the battery level, when it gets low, the engine kicks in to charge it. Nothing to worry about, just drive and enjoy...
  7. Paul58
    1,126
    125
    Atlanta
    That's an aftermarket add-on... The solar panel that comes with the solar roof option only operates the fan as mentioned above...
  8. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I understand that. The current plug-in conversion and the solar panel are both aftermarket add-ons.
    Let me narrow my question down further.
    I have two options right now (if I even decide to go with either one).
    1. The Enginer plug-in conversion. $2495 for a 4kW option.
    2. Solar panel add-on. $3500 for the kit.
    I can't plug in at work and maybe not everyday. This is why I was looking at the solar panel option. I understand it's not the most efficient process to charge the batteries but the sun is free and I don't have to remember to do anything.
  9. Paul58
    1,126
    125
    Atlanta
    I understand your question better now... So, my questions would be: Are you looking at a 2010 Prius (Gen 3) or the 2005-2009 (Gen 2)?
    I noticed the web site you referenced sold the 2009 and older Prius already equipped with the solar panels for $25,000 as is... This seems pretty steep being as you can get a new 2010 Prius II for under $20K, and they make a plug-in kit for the 2010.
    So, it would seem to me that you could get a 2010 with the after market plug-in for less. Keep in mind the plug-in just extends the range (the same as the solar kit), and it would still work as any other Prius otherwise, i.e. once the add-in battery depleted.
    Having said all this, it seems to me the plug-in is the better deal because you can charge it overnight and get the added benefit on your way to work, which would give you the advantage of extended range 50% of the time, and net you a new vehicle for less money... Just a thought...
    My personal opinion would be to forgo either option and just be happy with the 50+ mpg you'll get from a regular Prius! That additional $2500 - $3500 will buy you a lot of gas!
  10. FirstFlight
    FirstFlight Member
    429
    77
    New Jersey
    I'm actually looking at the 2011 model. If my memory serves me correctly, it has a bigger ICE and electric motor. I was thinking of trying to hold out for the 2012 PHEV but don't know what the cost will be and if a PHEV isn't right for me, what's the point of waiting?
    Yes, they are selling the Prius for $25K with the solar panel but I would do it myself if I did buy it. The plug-in conversion seems cheap and a good add-on but the problem is I don't know how often I would be able to plug it in (hopefully 5 out of 7 nights) so I'm not sure financially it would be right for me.
    However, for $2495, it's one of the least expensive add-ons to extend the range.
  11. Paul58
    1,126
    125
    Atlanta
    FYI... Do a search of this forum ref: 2011 Prius. It's been reported by the Toyota Design Team that the only real change for 2011 over 2010 is the availability of Bisque interior with Black exterior and the addition of the brake over-ride that is supposed to kill the engine if the accelerator and brake are both pressed at the same time.
    If you're not wanting to wait for the PHEV, then it would be more beneficial to take advantage of the end of year pricing and get a 2010. I paid $3000 under invoice for mine, that would more than cover the cost of the Enginer 4Kw Kit you are considering!
    I would think that plugging in 5 out of 7 days would still net you some savings, but you would have the same issue with the PHEV. Being as pricing has yet to be set on the PHEV, you'd be better off getting a 2010 and adding the 4Kw Plug-in Kit.
    I still think the best bet for you would be to not worry about the add-ons, especially if you don't think you'd plug it in and it doesn't appear they have a solar kit for the Gen 3 Prius... The saving from not purchasing either kit would fuel your new Prius for a year or more...
  12. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Given the length of your daily commute and other information, I would recommend a 2010 prius and not add any type of after market battery enhancements. I have a similar daily commute (mine is 70 miles round trip) and I figure to put on 25,000 per year. I considered maybe getting a used second generation Prius and having an aftermarket kit added to it, but for most of the kits, I would only get about 25 miles range before the kit would need to be recharged. This wouldn't greatly improve my overall mileage. Had I a daily 20 mile commute and could do it on a single charge, I would have strongly considered getting an aftermarket kit.
    I'd skip the aftermarket stuff and get the 2010 that you'd like. There is no change that has been mentioned for the 2011 that makes it "worth" waiting for. The engine change was from the second generation Prius (Model years 2004 - 2009) to the third generation Prius (Model year 2010).
    Hope this helps.
  13. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    What battery are you referring to here? If you're referring to the NiM HV battery in a Prius, don't worry about its state of charge. The car will prevent keep the SoC between ideal ranges. (From my experience on my 2nd gen), 80% is full. The car does funky things once you get near or at 80% and are coasting to prevent it from going above it. When you shut your car off, the SoC could be at nearly 80% or almost "flat" at ~4x%. It doesn't matter.
    I agree w/both of the above. I'm not sure why the OP is so hung up on aftermarket kits. The Prius, as it's shipped is not an EV. It has a bunch of limitations like the ICE having to spin >=46 mph (please correct me if I'm wrong on 3rd gen value, it's >=42 mph on the 2nd gen). It won't let you go very fast in EV, if you turn on EV mode via the EV button.
    Although I don't usually read http://priuschat.com/forums/prius-phev-plug-in-modifications/, the OP might be advised to do so. http://priuschat.com/forums/prius-p...er-almost-non-stop-electric-vehicle-mode.html seems like a useful starting thread.
    Also, the HV battery and many HV components are warranted for 8 years/100K miles. If the OP is in a CARB state, it's 10 years/150K on the HV battery. I'm not very familiar w/the Enginer kit, but although they say it's unlikely their kit could cause any vehicle damage, if it does, they don't seem to offer any assurances of covering your repair costs.
    I have never heard of http://www.solarelectricalvehicles.com/ until now, but they don't even list a price, let alone any sort of warranty assurance.
    I also find the claims on their site like those on http://www.solarelectricalvehicles.com/products.shtml and http://www.solarelectricalvehicles.com/faqs.shtml to be questionable, esp. "The electric mode driving range will be up to 30 miles per day depending on driving habits, speed and conditions." and "The SEV system provides up to 30 miles per day in the battery solar mode, increasing fuel economy." That seems VERY unlikely given a supposed 215 watt panel output. (1 horsepower = 745.7 watts)
    To be of much use, one would need to add an extra battery w/FAR greater capacity than that stock NiMH HV battery to store up that extra electricity. One can only go a mile or two on level ground the stock HV battery before the ICE kicks on.
    It's unusual (to me) for prospective Prius buyers to even consider aftermarket kits or panels before even having the car.
    From what we've seen w/the Prius PHVs that have been loaned out to some folks (and is being deployed to fleets), what it offers (including its changes) does change the equation significantly. But, we'll have to wait awhile for it and the price is unknown. It's also unclear how different the final production ones will be. I'd imagine that some of the quirks (e.g. no EV mode button/toggle) will be addressed.
    Nope. The larger ICE came and higher total net hp (134) came w/the 3rd gen (2010 and beyond). 2nd gen was had a smaller and weaker ICE and total net hp of 110.
    The thread on this is http://priuschat.com/forums/gen-iii-2010-prius-main-forum/82748-my11-prius.html. Also search for other posts by the user Prius Team in that thread.
    The folks posting as Prius Team are official Toyota Motor Sales marketing people.
