Not the usual rear hatch problem
Discussion in 'Gen 2 Prius Main Forum' started by Gromit!, Dec 4, 2022.
  1. Gromit!
    Gromit! Junior Member
    Boston
    I expect everyone who frequents PriusChat.com is familiar with the Gen 2 hatch opening problem — the gummy rubber cover over the hatch release switch. Well, my Prius doesn't have that. But the hatch still won't open much of the time. Often it doesn't release at all. Sometimes it partially releases but will only come up about an inch and no more.
    To be clear, it had the common problem with the switch cover, but I fixed that: I actually bypassed the original switch and installed a weather-sealed pushbutton switch with more definite tactile feedback. This works a treat and I can clearly hear the mechanism actuating every time I push the button. But the problem still remains: Sometimes only lets the hatch up an inch, sometimes not at all. Sounds like the latch mechanism itself is defective, right? Good hypothesis. But I replaced it and nothing changed. Low voltage from the 12V battery? Nope, it's less than 2 years old and measures at a healthy 14V when tested with the car shut off.
    If I press the button over and over it eventually releases and lets up the hatch about an inch. Then if I push the button repeatedly while jiggling the hatch it eventually releases completely.
    I've searched all over the web and only found one instance of someone experiencing these symptoms (on another Prius forum) and that thread ended after just a couple of replies and no solution.
    Have I missed something on Prius Chat? Or elsewhere? Anyone have any further suggestions? It's a 2007 Prius Touring Edition with 120,000 miles and in generally great condition other than this one annoyance.
  2. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    When was the last time you replaced the hatch struts?
    #2 SFO, Dec 4, 2022
  3. PriusCamper
    PriusCamper Senior Member
    12,064
    4,896
    Pacific Northwest, USA
    This would be a good thing to look into... It's also possible someone hit your rear bumper hard enough that it bent in that rear panel the latch bolts to and its no longer properly aligned and you need to remove the latch and take a big hammer to the mount so it's bent back further and lines up better.
    PS: Can you post a photo of your replacement switch as well as where you can buy them?
  4. Gromit!
    Boston
    Well, the hatch struts were replaced last year (and applying manual upward pressure when pressing the switch doesn't help).
    The rear bumper has never been hit, so I'm pretty sure the alignment is OK. I've already tinkered with it a little but I'll have another go at that.
    I bought the switches on eBay — pack of 5 for $6.95!
    (I do a lot of electronic work so I'll use the rest eventually)
    BTW: You can get the switches on eBay, item number 382593121812
    #4 Gromit!, Dec 4, 2022
  5. PriusCamper
    12,064
    4,896
    Thanks for the link... So you're saying it clears the latch and gets an inch high and gets stuck? What happens when you force the issue?
    Once it's clear of the latch it's just the struts and hinges and if you've never washed your car you could have lots of debris around those hinges causing this. Or maybe the metal where hatch connects to the roof... has been damaged?
    #5 PriusCamper, Dec 4, 2022
  6. Gromit!
    Boston
    I'm confident it's not related to the struts or anything else above the latch itself. When it does stick, the latch behaves a little like the hood latch: after you initially release the hood latch the hood releases and springs up an inch and you have to manually release a secondary safety catch. The rear hatch is behaving the same way except that of course it doesn't have a secondary catch to release. It appears to be the main latch mechanism itself that's catching something and not allowing the hatch to release all the way.
    When it does stick this way I can hold in the release button and jiggle the hatch up and down (and I can hear it catching on something) and it will eventually come loose.
  7. PriusCamper
    12,064
    4,896
    Well if it's not entirely clearing the latch then it's not opening an inch first, but less than that. Clearly your problem is the latch. And because you already replaced that once, you'll have no problem pulling it out and cleaning and inspecting and greasing. I bet that's the only problem. Or perhaps your replacement latch is still under warranty?
  8. ChapmanF
    17,345
    It doesn't have a separate, finger-operated catch the way the hood has, no, but it does have a two-stage latch. If you have the hatch open and use your pinky to push down the latch, you'll notice it has two clicks.
    Sometimes I use too brief a touch on the open button for mine, and get it unlatched just up to the next click. Then I pull on the hatch, it goes bonk, and I have to look a little sheepish and push the button again.
    If something is slowing down / gumming up the motion of the latch or your lifting of the hatch, that could happen more often.
    PriusCamper likes this.
  9. PriusCamper
    12,064
    4,896
    As someone who's Prius is loaded with gardening tools full time and I'm constantly moving trees and plants and debris around, this latch wears out and fails real quick if you aren't constantly cleaning it out. I pulled my latch and cleaned and lubed it so many times that I finally had to replace it because it was worn to broken in multiple ways.
  10. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,080
    Columbia, SC
    Try putting a little bit of downward pressure on the hatch with one hand while pressing and holding the latch button with the other. Works for me. Other times it's just the weather stripping stuck to the paint.
  11. SFO
    SFO Senior Member
    5,302
    4,245
    Northern California
    Where's Wallace? :whistle:
  12. mr_guy_mann
    mr_guy_mann Senior Member
    3,966
    1,914
    NJ-USA
    +1 to ChapmanF
    The tailgate latch does have "2 stages". If you close the T/G too gently the latch won't fully seat ( to the 2nd stage) and won't turn off the interior light or dash indicator ( which = dead 12V battery).
    So it's possible for the latch to release only "part-way". My first thought would be to check if striker loop on the T/G is rubbing on the side of the receiver slot on the latch. Maybe the latch mounting needs adjustment or the striker is slightly bent?
    I use a screwdriver to manually close the latch with the T/G open. Then trigger the opening switch while lifting on the screwdriver to test how well the latch releases. (Maybe the voltage to the latch release solenoid is low and doesn't work correctly?)
    T1 Terry likes this.
  13. T1 Terry
    T1 Terry Active Member
    744
    402
    I'll second that one, with a larger sized phillips screwdriver, push the round shaft through the latching mechanism to get the two stages of latching, then press and hold the button while trying to pull the screwdriver back out to open the latch. If that works ok, check that the aligning pads aren't pushing the tailgate to one side as it locates in the latch and that is what is causing it to jam.
    Mine has the opposite problem, sometimes the latch will close into the first step while the tailgate is up, the door section then pushes the the latch to fully locked position and no tailgate latching .... I have to continually flick the hatch opening bit while pulling the screwdriver back through the latch to get it back in the open position.
    T1 Terry
  14. archibald tuttle
    archibald tuttle Junior Member
    81
    Rhode Island
    the unusual gets usual. i've got similar issue. but i don't seem to be lucky enough to get that 'second' stage to release. Now that it is mentioned, I realize that, historically, i have been fighting that second stage since i bought the car but the second push and pull would release it.
    I have to admit, i never thought of it as staged but now that the first stage clearly releases and the second never does that is clear. to make more of a conundrum, if i only shut it hard enough to engage the 1st stage, then it releases easily with the button, but if i shut it all the way it only releases from the 2nd or fully latched stage to the partly latched circumstance, but will not release that 1st stage and i have to crawl inside and trigger the manual release.
    I haven't spent time yet messing with the latch and a screwdriver, but hearing that someone with a similar problem got no result from replacing the latch itself leaves me perplexed. i don't observe any side to side alignment issue. And I get wonder why there even is a 2nd grab. maybe it is meant to prevent an accidental trigger from resulting in the hatch opening (I would think that could only be a problem when the lift cylinders are like brand new, because the geometry is that the ones i've got don't really start lifting until you get the gate open a little by hand, or maybe it is intended so if there is something preventing the gate from closing all the way it will still be latched?
    i wouldn't exactly call this planned obsolence, but maybe unplanned???
    Brian
  15. Leadfoot J. McCoalroller
    7,861
    7,329
    Pennsylvania
    2018 Prius c
    US Federal motor vehicle safety standards require double-latch closures in certain uses, and the back door of a Prius qualifies.
    drone13 likes this.
  16. Gromit!
    Boston
    Yep, that's exactly how mine behaves, though I haven't tried using the manual release from inside; I just keep pressing the release button while jiggling the hatch up and down a little and it eventually releases.
    At least I've found one other person with the same problem! Please post if you find a solution.
  17. T1 Terry
    744
    402
    If you remove the trim to expose the solenoid that pulls the cable, try manually pulling the cable till you get the latch to release both stages in one go, that is how far you need the solenoid to pull, but no further. The magnetic field in the solenoid is the strongest at the end of it's stoke, if the iron core can not travel far enough to reach the end of the windings because the cable is too tight, it won't have the pulling power to fully release the catch. It might take some fiddling to get it exactly right, but that generally fixes the problem.
    Another test is to measure the voltage while the solenoid is being operated, a poor cable connect of switch will cause excessive voltage drop and the magnetic field won't be strong enough to actually fully release the catch.
    T1 Terry
  18. archibald tuttle
    81
    Rhode Island
    the government here to help us again. should have known. got enough trouble keeping single stage latches working . . .
