Note on the advanced model phone charging app
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by tomkessler, Mar 4, 2012.
  1. tomkessler
    tomkessler Junior Member
    28
    Campbell, CA
    I remember when ordering that there was an advertised smart phone app for monitoring charging, turning the a/c on remotely, setting charge timers and so on.
    After a lot of head scratching, pawing through app stores, and thumbing through the manuals I realized there's a tiny little asterisk in the brochure saying it's available in the summer of 2012.
    So, I hope I save someone else some time.
  2. jbrad4
    jbrad4 Active Member
    474
    148
    Rowlett, TX
    Tom, You did save me time in looking for it.
    Thanks.
  3. SimiPrius
    SimiPrius Member
    247
    60
    Simi Valley,Ca
    It works through Entune. You have to register on the website and set the options there. You can check charge status and start cooling the car remotely.
  4. CharlesH
    2,796
    1,163
    Roseville, CA
    I configured mine and it works just fine. You have to have activated your (pre-paid) Safety Connect as well as registering for (also pre-paid) Entune. The Entune registration includes options to opt-in to the plug-in application functionality. You then download the Entune application to your iPhone or Android phone from your phone's app store. You do the Bluetooth pairing with your phone, and then go to the App setup on the car, which will load a bunch of stuff (I don't know if it is loading it to the car or to the phone). But then when you launch Entune on your phone, you will see the special Plug-In applications in addition to the media stuff like Pandora.
    You need the Safety Connect feature activated, because the Plug-In smartphone application uses the cellular modem built into the car to talk to your car. This is the way the SOS button and the theft tracking works.
    I just called Safety Connect and given the VIN, they found the account with all my personal info already there. They asked for a couple of additional items like a password if you call in to report a theft. Make sure that they e-mail you the completed contract, since it has the contract number you need to enable the plug-in apps in Entune.
  5. tomkessler
    28
    Campbell, CA
    Right, I figured out you need to register for the safety connect. The manual isn't very clear on this point.
    Also, on my iphone at least you need to log out and then log back in to the entune
    application after you vehicle comes online.
    It does look like some of the apps are coming later in the summer. At least the charge timer, charge and remote A/C ones are working now.
    OK, back to fooling with iphone and entune interactions...
  6. Prius Team
    Prius Team Toyota Marketing USA
    681
    1,817
    CA
    In case it helps...lots more being added, but this should be a start for many of you that haven't read through this site:
    Prius Plug-in Advanced Model Only
    Best,
    Erica Gartsbeyn
    Prius Product Manager
    Toyota USA
  7. dsss
    dsss New Member
    16
    Thanks Erica. Is there any chance that you could add functionality so that the charging app could email/text the user when the charge is completed (like the Chargepoint app).
  8. CharlesH
    2,796
    1,163
    Roseville, CA
    Actually, the Entune Plug-In setup already allows you to get e-mail at any combination of when: 1) charging starts, 2) it ends normally, or 3) it is disconnected before charging is complete. I have verified that it works: my Blackberry beeped that I had mail within ten seconds of when I disconnected the charger.
    My real phone is a new Blackberry, but I had to reactivate an old Droid to get the Entune application with the plug-in apps. The plug-in apps are not supported on any Blackberry, and the media Entune apps are only supported on old Blackberries.
