O2 sensor monitor never completes
Discussion in 'Gen 2 Prius Technical Discussion' started by david95376, Oct 30, 2019.
  1. david95376
    david95376 New Member
    Sacramento
    Hello all. This is my first time posting on this forum. I have a 2008 Prius that I bought used in spring of 2018. For about 18 months on and off, I have driven the car in attempt for get all of the monitors ready. I have also followed the drive cycle specification.
    Within the past year, I have driven the car hundreds of miles with the following results repeatedly:
    - I reset the ECM
    - I drive hundreds of miles, frequently checking monitor statuses and DTCs
    - No DTCs ever appear
    - The only monitor left to complete is the oxygen sensor one
    - When I reach a certain mileage, the large red triangle appears, along with multiple amber lights, of which I forgot to take note
    - I reset the ECM again
    Does anyone know why the oxygen sensor monitor never completes?
  2. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Welcome to PriusChat!
    How many miles are on the vehicle ?
    How are you monitoring for DTCs (which device, etc) ?
    When was the last time the oxygen sensor was replaced (upstream or downstream) ?
  3. Aegean
    Aegean Active Member
    464
    208
    Alexandria VA
    Well I had another vehicle with the same issue. The monitors were never complete and therefore in Virginia I could not pass emissions to renew my registration. After extensive research and two dealer diagnosis visits it was never resolved. Luckily, I learned about a technicality, the Ford Excursion was over 8500 pounds and was allowed to pass emission with the old tail pipe sniffer.
    I am glad I do not have to deal with anything similar anymore because both my 2006 Prius are exempt from Emission testing in Virginia.
  4. david95376
    Sacramento
    The vehicle currently has a mileage of 166,520. I use an ELM327 WiFi OBD scanner along with OBD Auto Doctor on my laptop. The downstream O2 sensor was replaced earlier this year, with a Kwiksen brand OEM-compliant sensor. After a few months, the upstream O2 sensor was replaced with a new eBay one, which caused DTC P2237 to appear, so it was again replaced a few days ago with a used (junkyard-sourced) O2 sensor which had no DTCs. However, the upstream usually has a reading between 2 and 6 volts, according to a graph shown by OBD Auto Doctor, regardless of how many times I've replaced it.
  5. david95376
    Sacramento
    The above screenshot was when I had a family member drive the car with stop and go traffic.
  6. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    After the fault lights come on did you read the codes? There has to be codes.
  7. SFO
    SFO Senior Member
    5,302
    4,249
    Northern California
    Never heard of the application before, my guess is OBD Auto Doctor isn't offering you the DTCs needed.
    Please find a generally recognized app or program from this forum and try scanning again : Prius OBDII Third-Party Apps | PriusChat
  8. david95376
    Sacramento
    Will try a different OBDII app, but the vehicle finally threw a code, P0A80. I might consider selling it at this point.
