O2 Sensor Troubleshooting Help…..
Discussion in 'Gen 2 Prius Main Forum' started by Michael Crestohl, Oct 5, 2022.
  1. Michael Crestohl
    Michael Crestohl Junior Member
    61
    Marblehead Massachusetts
    Hi All….
    My 2007 had its cat stolen and the previous owner replaced it with an aftermarket cat and aftermarket O2 sensors. The CEL is on and shows a P2237 error code which I have decoded as follows:
    “HEATED OXYGEN SENSOR (HO2S) 1 Bank 1 positive current control open circuit”.
    I want to try replacing the cheap aftermarket O2 sensor in the hope that the CEL will go out. Can anyone tell me if the above error message indicates which of the two O2 sensors is causing the problem?
    Are the two O2 sensors the same part number.
    Thanks again for all the wisdom and experience.
    Michael…
  2. Tombukt2
    Tombukt2 Senior Member
    13,110
    2,353
    Durham NC
    I don't believe the 2 02 sensors are the same. They generally have different part numbers but the code that you have is dealing with the heater part of the O2 sensor so I'm not sure whether it's able to detect whether the O2 sensor is in heating which I don't think is the case It sees some trouble maybe in the line voltage that's supposed to make the heater heat could be as simple as a fuse blown
  3. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,092
    Columbia, SC
    You want the downstream sensor. DENSO 2344623. Go to RockAuto.com where they have 'em for about $50
    Don't waste your time with anything else.
  4. highmilesgarage
    highmilesgarage Active Member
    479
    177
    Kansas City
    is that bank 1 sensor 1 which is upstream sensor?
  5. ChapmanF
    18,305
    If I had the Gen 2 manual open right now I'd get the complete answer from the code's detection condition, but anyway, the fortune cookie already quoted said open circuit for the heater, so that's probably what the code detects.
  6. Michael Crestohl
    61
    Which fuse do you think it might be.
    Tombukt2 likes this.
  7. dolj
    dolj Senior Member
    8,458
    4,294
    Wellington, New Zealand
    I don't think I'd trust that scan tool as P2237 does not appear to be a valid code for a Gen 2.
    There are no Gen 2 DTCs that reference 'positive current control open circuit' either.
    As for bank 1 or bank 2, I'd want a valid code first just so I'm not chasing my tail.
    However, P2238 and P2239 are valid codes:
    • P2238 - Oxygen (A/F) Sensor Pumping Current Circuit Low (Bank 1 Sensor 1)
    • P2239 - Oxygen (A/F) Sensor Pumping Current Circuit High (Bank 1 Sensor 1
    I'd be inclined to try for a second opinion using a different scan tool.
  8. Tombukt2
    13,110
    2,353
    Durham NC
    I don't know but you have a little fuse puller in your fuse box and I would just lift them up and see which one is burnt or use my fluke and check em . Test light whatever .I'd be finished time I write this. Because in my vehicle there are never any fuses burnt ever for any reason and if there are we're going to find them 60 seconds there's only two places for them. But I don't know which one controls the heater circuit for the O2 sensor or sensors. Another way might be to turn the car on and measure the wires that the plug of the O2 sensor does the wire that runs the heat whether that's black and white or the blue or whatever I don't know can't remember I try never to touch the O2 senses except every 200,000 mi and that means replacing
  9. TMR-JWAP
    6,404
    6,092
    Columbia, SC
    Anyone that gets a cat stolen from a Gen 2 loses the downstream O2 sensor. Nobody I've ever seen in this situation loses or replaces the upstream sensor, which is mounted in the exhaust manifold and is a bit of a PITA. Anyone I've seen that has replaced the downstream sensor with a cheap chinese $15 sensor from ebay typically gets what they pay for. I've installed quite a handful of aftermarket cats on Gen 2s. That DENSO has been bulletproof.
  10. Tombukt2
    13,110
    2,353
    Durham NC
    Yep if the cat's taking they're certainly not unscrewing the sensor so be ready to buy a new one I've only had good luck with the denso and the Bosch that come with the plug and splice kits never had a problem with either.
